quick megan manifold question
just curious to know if the stock turbo lines line up still when using a megan turbo manifold? Will still be using the stock t28 on an s14 sr but need to know if i have to get steel braided lines or not.
Thanks. |
![]() Join Date: Aug 2007
The stock lines will work just fine. But as with any aftermarket bottom mount manifold though, you might have to do a small amount of bending by hand to get them to line up properly. Make sure to not use thread tape on the fittings!!! Lastly, be sure to use the support brackets that are included, or the manifold will crack.
#6 | |
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
Get the braided back. My stock lines went out (cracked or split, I havent pulled the motor yet) this last weekend and left me stranded at the track. Whhheee.
http://buildmakecreate.tumblr.com/ |
