![]() Join Date: Sep 2004
EVERYTHINGS SOLD....Thanks guys!
SYNAPSE FULL V-Band Complete Turbo Kit First I have a slightly used Synapse V-Band Turbo Kit w/ a perfect used Garrett GT3076R .82 a/r turbo for sale. Includes everything you need for a complete top mount setup (minus downpipe and hot pipe). Say good bye to LOOSE turbo bolts and BLOWN turbo inlet gaskets FOREVER!!! Don't let that ruin your day at the track!!! Turbo Kit Includes: - SYNAPSE Turbo Manifold for s13 or s14 sr20 w/ LIFETIME WARRANTY from cracks. - Garrett GT3076R Dual ball bearing turbo - Tial V-Band Inlet/Outlet Exhaust Housing - Tial Inlet Clamp (from turbo manifold) - Tial Outlet Clamp (to downpipe) - Tial 44mm V-Band Wastegate w/ .7 bar or 10.15psi spring (with all hardware) - Synapse SR20 Turbo Manifold - Circuit Sports Top Mount Turbo Lines - AGP Oil Drain -10AN with stainless braided -10an drain line - Blue silicon Inlet and outlet couplers (4 inch to 3 inch coupler for turbo intake to z32 maf and 2.5 inch to 2 inch coupler for turbo outlet) Same kit sold here Synapse V-Band Turbo Kit for SR20DET (GT3076R) The Garrett GT3076R Dual ball bearing turbo for sale was only used on the dyno until tuner realized that the headgasket was leaking boost pressure. Turbo and kit was removed right after and has less then 100 miles on it. Turbo has no shaft play, felt the same way as it did when it came brand new in box. Turbo Specs are: -Garrett Dual Ball Bearing Turbo -GT3076R (aka GT30R aka GT3037) -Tial .82 a/r exhaust housing with v-band inlet and v-band exhaust outlet -T04E style compressor housing with 4.00 inlet and 2.00" outlet. Compressor inlet has a machined ported shroud (anti-surge). Very Good response turbo for 4 Cyl applications. This turbo has a flow capacity of about over 500HP. Turbine -Wheel: 60mm w/ 84 trim -Housing: .82 a/r Compressor -Wheel: 76.2mm w/ 56 trim -Housing: .60 a/r Turbo was stored with tape sealing all open ports on turbo. Tape was taken off only for pictures. I am looking to get $2000 SHIPPED for the complete turbo kit. SOLD!!!! PICTURES: Fins are absolutely free from chips. (Black paint is fading may look like chips) Dont mind the SUPER Sharpie...made the turbo look a little dinky in pictures haha A look into the compressor outlet. Clean. Pictures of manifold, wastegate, turbo lines, and misc. Turbo manifold only has surface rust from my Dmax vented hood. NISMO 740cc Injectors ****SOLD**** Also for sale are slightly used NISMO 740cc Injectors. In very good condition, plastic tops are perfect and not damaged in anyway from being removed from fuel rail. Injectors were barely used and was not driven on during the winter months. Only actually driven on for only 6 months. You can tell how lightly discolored the plastic guards are around the injector spray nozzle are (usually the longer you have them in the rail the more darker and browner they are, A TIP when buying fuel injectors. Typically you'd want the injectors that are not used for very long if buying used because these are a wear item and degrade and get inconsistent as they age). All injectors were individually wrapped and double bagged with paper bags to insure that they wouldn't bang against each other while being stored. Will throw in S13 SR fuel rail for free. Im looking to get $400 SHIPPED (buyer pays paypal fees) Pictures Selling both turbo kit and injectors separately. Will not part out turbo kit or sell injectors one by one. WOULD be happy to throw you a good deal if you are interested in buying both turbo kit and injectors. PM ME!
![]() -Jeff Wolfson Last edited by SpdElemts; 08-14-2009 at 03:10 PM.. |
Last bump i guess.....im not looking to part anything out at the moment, but to those who PM'd me ill let you know once i do. So yea still for sale guys shoot me reasonable offers. Times are tough i understand so shoot me something. Need to get my new car finished.
![]() -Jeff Wolfson |
Here is a picture of how the turbo sits. Pretty far from the BMC will never need to worry about your master cylinder catching fire. One of the best placement turbo manifolds imo. Price lowered to $1800 shipped you pay paypal fees.
#10 | |
EDIT: actually if i find someone that would be interested in just the manifold...ill work something out with with either of you guys.
