After scoring a cylinder wall and beating up the quench pad im done with Rb motors. I dont want to rebuild it I just want something differant. This was a functioning rb25det neo, so anything you can think of swap related is for sale.
Apexi Powerfc D-jetro ecu setup. Brand new in box!!! Fits R32 and R33 Gtr rb26dett. Comes with Ecu, hand controller, Map harness, and 2 New Gm 3 bar map sensors with pigtails. Get rid of those pesky mafs and restrictive intake plumbing. 875 covers shipping and pay pal fees. : Second PowerFc for Rb25det S1. Perfect working order. Comes with hand controller. Sold. Nismo 550cc injectors yellow tops x6 perfect working order. Comes with new Sard fitting. Sold Stock 370cc injectors for rb, x6 in working order. Sold Z32 maf working order, has flange for adapter ground off so you can put a hose coupler on instead. 50 Neo clutch fan. Works great. Fan and clutch sold Grand National coil kit. Includes Coil packs, Taylor plug wires labeled, Ignitor pigtail hookup. Sold Rb25det 5 speed transmission, working order no grinds. Sold Rb25det flywheel, 50 Nismo clutch slave cyl. Used 3 months. Makes stiff clutch pedal feel stock. Sold Act rb25 clutch kit, repadded 2 events ago. Lots of life left. Sold Driveshaft shop s13 rb driveshaft. Steel version. Used a couple years. Sold Custom mounts for rb into s chassis. Includes both motor and trans steel mounts. Way nicer looking than mckinney. 250 Rb25 S1 intake manifold moddified to forward facing throttle body. Keeps long factory runners that help make torque. Sold Rb25 s1 engine harness runs great and ran on switch panel. 150 Rb25 starter, working. Sold Rb25 alternator, working, 80 Rb25 power steering pump. 70 Rb25 stock exhaust manifold. 20 Z32 brake caliper, driver side 30mm, just 1. Sold Nismo N1 water pump used one night. Some surface rust from sitting outside. Only used 50 miles. Sold Hit it with scotch brite for 20 seconds and it cleaned up. Rb timing tensioner and idler, used one night. Sold Rb25 neo awd oil pan modded to be rwd. Center diff cut off and plated closed. Sold Good for rb26 converted to rwd configuration, or awd neo block to rwd config. Much more rigid than stamped steel oil pan. Has extra -10 oil drain welded on. Neo timing garnish black plastics. No damage. Has lil plastic cover for cam sensor wire, not pictured 70 Neo cam sensor working order, 150 Neo crank pulley, no stuck bolts, no chips. Sold S1 valve covers tapped with 90 degree dash 10 an fittings. Sold T3 60-1 turbo in great shape made by Precision Turbo. Shaft play is tight and spins smooth. Stage 3 exhaust wheel with .82 a/r exhousing. Compressor wheel looks great, always filtered no debris. To4e compressor cover. Comes with billit -3 oil feed and -10 oil drain fitting. 400 Rb26 stock connecting rods. Great shape. No Bluing or spun bearings. Set of 6. Sold Dual -10an inlet oil catch can with Moroso filter. Lines not included. Sold Prices before shipping and paypal fee unless otherwise noted. Thanks for looking!
futurefabrication.com Last edited by FutureFab; 02-13-2013 at 09:27 AM.. |
What stage it the clutch? And can we get a brighter picture of the n1 water pump blades
4MationD! 90se RB26:build,95pgt KLZE swap:daily,92le vh45 swap planned
Hey If possible are u willing to sell m the base and shifter assembly and that tube for the head to block oil drain? I deperatley need them parts name a price if so...
Im not parting out the trans. Hard enough to sell for a good deal at 500. The neo doesnt have external head drain otherwise id sell you it. Thanks for asking tho.
futurefabrication.com |
#29 |
The dejeto 26 can work on rb25 s2 but wont be able to control variable cam. It may need a couple pins repinned. Dont know off top of my head if the pinouts are exactly the same.
