hello all! i had an idea to put these wiseco forged pistons for a dual cam into a single cam. i have searched around and have only found info about swapping single cam pistons into dual cam motors to raise the compression. the piston specs are 89.5 bore and 9.0:1 compression ratio. how would this affect the compression ratio in a single cam motor? if this is a possibility i would go turbo.
my car is an 89. not sure if it is 8.6:1 or 9.1:1. i can check manufacture date next time i drive it. any feedback on this is appreciated! |
![]() Join Date: Jan 2010
A 7:1 CR motor would be the laziest thing you'd ever drive in your life. Why not just put single cam pistons in it and run 9:1 comp? With a good tune that's not dangerous or anything, even on 91..
gotchya. i was curious about it because i already have the pistons for a dual cam but decided to go another route and build up a single cam. i will just list them for sale online and get single cam pistons. appreciate the responses guys. thanks a bunch!!
89.5 so .5 over stock and 9:1 comp. came out to about 600 including tax and shipping. lmk if you want them! |
| 240sx, ka-t, ka24de, ka24e, pistons |
