![]() Join Date: May 2012
PBM comp question
Got my PBM competitions today I mounted the rear fine when I went to throw the fronts on I mounted the tops fine and when I got to the lower hub bolts the pbm hole to fit the bolt through is too skinny to fit the OEM size bolts... Any suggestions? The car is s13 hatch
![]() Join Date: May 2007
Do you maybe have s14 lower control arms? Because you might also have s14 hubs, which would mean you have a larger bolt for that. I'd just get a 14mm IIRC drill bit and fix'r up. Or contact PBM and see about getting s14 lower mounts.
Definitely double check though.
Just go get s13 bolts. I have the same setup and got a spacer so I could use the s13 bolt on s14 knuckles with no play. Otherwise, just drill out the hole.
![]() Join Date: Oct 2009
![]() ![]() Feedback Score: 11 reviews
i don't know for sure. but you should call the konig distribution center. they'll know for sure. speak to greg. tell him steve sent you there.
@dangerdamian |
