rb25det falls on face around 3500rpms
Ok so im stumped on this one guys i have tried everything i can think of so now i come to yall for help. so my rb will run and hold a steady idle but when i rev it up it gets to around 3500 rpms(assuming my tach is reading correctly) and it just completely cuts out and will not rev higher, but will not die, the idle will just drop down to 300 or so then will bump back up around 700 or so and will maintain there.
i have boost leak tested my system and have sealed all the leaks i found. i have my timing set to 15 degrees btdc which is stock timing. all my spark plugs are new and are properly gapped. after all this i figured i would try unplugging my MAFS and it ran the same way plugged in or unplugged so i replaced my MAFS and still i have the same problem. the only thing left i could think to check would be the TPS which i will check later tonight when i get my multimeter back. also at idle my boost/vacuum gauge is reading ten pounds of vacuum and when i do rev it up untill it cuts out my gauge will read at 0 and not go into boost. i am also not throwing any ecu codes. any help,advice, or input will be greatly appreciated as i am at a stand still |
![]() Join Date: Feb 2010
check TPS should be .4 - .5 volts throttle closed, also check MAFS voltage should be around .4ish volts ignition on engine off and according to fsm 1.1v during cranking but mine reads higher during cranking so i guess if its a little higher it should be ok, also check to make sure your getting MAFS voltage at the ecu
![]() Join Date: Dec 2006
are you using the correct MAFS?
yea im using the right MAFS and ive tried 3 now. i manually checked the ecu for codes last night and i am throwing a code for the MAFS i checked the conditon of all the wiring everything looked good and is correctly wired. i am going to check the mafs voltage later and see
