Old 12-24-2008, 11:11 PM   #1
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
fitment/stretch not what you thinking..
s13 with stock fenders.
Ok so back at one of the track days i hit a wall and got some fender, now on my passenger rear quarter pannel i got bondo, is it going to be possible to stretch/roll a fender with bondo if i am wanting to run a 18x10 or a 17x10 with a slammed car?
The bondo is right where you would stretch and roll a fender.
My concern is cracking/breaking the bondo and having to rebondo and paint all over again. I searched and searched sorry if it has been covered before, as you can tell i gots like no post because i usually can search and find the answeres i am looking for.
Thanks guys, lmk what needs to be done to fit this.
Dustxking is offline   Reply With Quote
Old 12-24-2008, 11:22 PM   #2
sidewayzsx
sidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura aboutsidewayzsx has a spectacular aura about
i dont think you can be able to roll/pull if quarter panel has been fixed with bondo...iv had smiler situation which led me into breaking/cracking it.
good luck tho
sidewayzsx is offline   Reply With Quote
Old 12-24-2008, 11:49 PM   #3
cwallace12
cwallace12's Avatar
cwallace12 is an unknown quantity at this point
Im pretty sure your out of luck. When your pulling the fender out like that your stretching the metal around that area also. Id say knock the bondo off and have a decent body shop take a whack at reworking the whole area. At least that way your get your fender pulled and they can pull out some of the old damage with a slide hammer.
cwallace12 is offline   Reply With Quote
Old 12-25-2008, 12:23 AM   #4
Dustxking
I pulled most of it out the old fashioned way by drilling and pulling.
Old 12-26-2008, 12:52 AM   #5
Dustxking
No more imputs?
Old 12-26-2008, 02:01 AM   #6
waynehead05
waynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura aboutwaynehead05 has a spectacular aura about
Send a message via AIM to waynehead05
It's going to crack definitely. (I majored in Auto paint and body btw)
Who in their right mind would want to lead this nation of Me-First Right-Now Do Nothings??
waynehead05 is offline   Reply With Quote
Old 12-26-2008, 02:49 AM   #7
Bushido
Bushido's Avatar
fuck yeah the bondo is going to crack if you try to stretch it. bondo doesnt have the same properties as metal.
get overfenders or a new chassis.
Old 12-26-2008, 12:33 PM   #8
Dustxking
Over fender time.
Old 12-27-2008, 10:48 AM   #9
g-via
bondo will definetly not be able to withstand a roll/pull. if you're lucky, you will just develop hairline cracks, but over time they will get bigger and bigger until something bad happens.
if you knew about this before you applied the bondo, you were better off shaping the fender while bondo-ing it and estimating how much roll/pull you'd need.
or just get overfenders!
g-via is offline   Reply With Quote
