Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Forced Induction
Closed Thread
Old 03-01-2013, 01:10 PM   #1
FRSport.com
FRSport.com's Avatar
FRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura aboutFRSport.com has a spectacular aura about
Send a message via AIM to FRSport.com
FRSport deal of the Day: Blitz Super Sound VD Blow Off Valve BOV Kit S13 CA18DET
Deal of the Day: Blitz Super Sound VD Blow Off Valve BOV Kit S13 CA18DET<--click here
Blitz Super Sound Blow Off Vave VD Venturi Drive BOV. The purposes of BLITZ Blow Off Valve VD is to relieve compressor surge without reducing compressor
speed. It controls boost pressure that is built up by the turbo and vents it into the atmosphere (some are recirculate) when the car is not under load (in
between shifts). This prevents pressure from backing up into the compressor housing, causing the turbo impeller blade to rapidly stop or even worse, to spin
backwards (compressor surge or backspin).
  • Employs the Dual Drive System succeeded from the Super Sound Blow Off Valve DD.
  • Employs high quality aluminum die-cast for the body.
  • Ensured heat dissipation radiation by designing the body and funnel with ribs.
  • Creates a sharp sound by adopting the Venturi effect.
  • Defric Coated Piston made smooth movement even under dusty conditions.
  • 36mm Diameter Big Valve with Special Rubber Seal ensured an outstanding sealing ability at high boost.
Available for $229.95
*price good while supplies last add to cart to receive discounted price*
Thanks,
FRSport Team
AIM: FRSportsales
Email: [email protected]
FRSport.com || 18050 Newhope Street, Fountain Valley, CA 92708 (Map link)
Store Hours: Mon - Fri: 8:00 AM - 6:00 PM PST
[email protected] | 800-321-4747 | 714-515-4001 ext 146
FRSport.com Open Box Clearance Items
FRSport.com Weekly Specials
FRSport.com is offline
Closed Thread
