New Title
You know after you've been driving for a while and you turn the car off and get out you can hear it makeing clicking/poping sounds? What is that and why does my car do it longer and louder than other cars I've heard doing it?
it is cause of the heat
when you shut it off then the colr air is making the poping sound the block is recompresing about doing it longer i dont know all cars r different another thing you can check it the coolant |
ya i never hear my s13
alltho i run the car very cool with the wide mouth bumper and every spring i change the coolant i dont think that it is a prob. :cool: (Edited by my240likenoother at 6:59 pm on Sep. 15, 2001) |
Guest
Posts: n/a
It should click a little, it's normal. Temperature change, nothing more than that. I only hear it from my exhaust (now that I've put a GReddy on. Stock didn't do it.)
![]() Join Date: Sep 2001
It's your cat......nothing to worry bout now. Cat converters get very hot and hold the heat (go ahead touch it!!). The clicking and popping noises r the different metals "moving around" as they expand and contract. If it glows red hot at night while running, it needs replacing. If not dont worry bout it!
Guest
Posts: n/a
I never knew that, thanks Yenpit!
