Hi fellas,
I am a new member to your forum and also a newbie on SR20DET (also my first turbocharged car). I have owned a supercharged S2000 before but dunno much about 240sx's and turbocharges. So, i have been searching for every information about the parts and any other things that i wonder about... Then, i have collected all the infos together and decided how the build should be according to my expectations. First, let me share with you my current build and then i will share which upgrades i will do... Mine is a 95' S14 SR20DET and my engine has; - CP piston set 86.5mm - Oem rods - Power Enterprise rod bearings - Power Enterprise Main Bearings - Tomei Poncams (256) - Garrett GT2871R 0.64ar (internally gated) - Oem turbo manifold - Tomei cam pulleys - Oem gasket set - ARP studs - Rocker Arm Stoppers - Nismo 800cc injectors - Cossworth head gasket - Walbro oil pump - AEM EMS ecu - AEM 3.5 bar map sensor - AEM air temp sensor - Slit Fire ignition set - Enjuku Racing intercooler kit - Tomei fuel regulator - Exedy Stage 2 clutch kit - And other parts... I am willing to upgrade; - My turbo to GTX2867R - My Oem turbo manifold to T3 Top mount Turbo manifold - I will do it externally gated (44mm Vband flanged Tial) My goal is to reach 400RWHP (350RWHP currently) and i am willing to drift my car so low mids and quick spool is at the first side. I need to know what do you think and your recommendations. Pls if you recommend anything, write in detail not only the part and brand name. All thoughts and recommendations on my build welcome. Thank you. |
#2 | |
![]() Join Date: Jun 2007
Greetings. Question are you posting a build of the car to its current point?
