![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
After searching through 5 pages I came up empty handed....... I finally recieved a bracket and tentioner for my sr and have had my DE pump waiting to be installed. The new bracket mounts up to the block nicely. The pump mounts up on the bracket nicely. The problem I am having is the tentioner is not lining up with the pump at all. It is way off. I know the pulley is in the right place because it lines up with its corresponding pulley on the engine. There is nowhere to mount the tentioner on the pump, absolutly nothing lines up. Hopefully someone else has had this problem and can lend me some helpfull insight. Thanks
#2 | |
![]() Join Date: Jan 2005
Trader Rating: (31)
pictures would help a bunch, as well as knowing what motor, i'm assuming your talking about a ka...
Slip Gypsies Blog Quote:
you have to have another braket, the bracket that goes on the ps pump itself, its is small and it goes on top of it.....
Sieze the day or Die regreting the time you lost
My S13 SR20DET Prep: SR20DET Forum (rear-drive): Nissan Forums / Infiniti Forums - NICOclub
detailed info an what you need
