Sunroof stuck
like the title says i need help with my sunroof. I checked the fuse, relay and motor. All working properly but it still wont close shut. I have no clue its for a 1991 240sx coupe help me out here any ideas.
![]() Join Date: Sep 2007
I thought they only came with a latch type thing.
I have the same yeah only hatch, and i've never seen one that's motorized.
![]() Gamertag:XxChumbawumbaxX |
i clean up the tracks and the motor couldnt be fried man cause when i hit the switch to close it was clicking and yes i tried closing it at the same time just wont go so what you think? you think i should disassemble the whole damn thing?
![]() Join Date: Jan 2006
somebody may have installed it
i dunno if they came with them or not anyway theres 2 types of sunroof actuation: like a door window with a gear arm or with a cable type if its gear arm type, its plastic and the teeth are sheared off if its cable type the cable is broken
ho ha ho chi chi |
hmm
maybe if you take off the plastic cover where the buttons are, there should be some sort of manual override? check it meng most power sunroofs have this feature
ho ha ho chi chi |
#11 | |
but what do u mean by manual override? |
like something you can put a screwdriver in or a allen key and turn it to close it manually
most cars with power sunroofs have them so that if your battery goes dead or some shit you can still close the sunroof
ho ha ho chi chi |
#17 |
btw, on s13's there were 2 style sunroofs...
the coupes got motorized automagic ones hatches got the manual pop up ones. back to the topic, i just checked the FSM, and they have no mention of a manual over ride, so ionno if there is one or not. They do have like 3 relays listed for it, maybe one is fried? have you tried just connecting a 12v power source directly to the motor? the only other idea i would have is to remove the motor, and then manually move the sunroof as there should be no resistance now ? good luck! |
#18 | |
whole motor and diconnect it ill be able to just pull it with no problem. |
#19 |
nono look at the rear of the motor where the shaft is
theres a gold nut on the end of it should be able to manually close with that
ho ha ho chi chi |
#21 | |
hes got power the motor works removing the motor doesnt remove the actuating device which would physically hold the sunroof in place just ssssshush
ho ha ho chi chi |
#22 |
#24 |
#26 |
well, considering you didn't even know s13s came with motorized sunroofs...
anyways, I figure if you remove the motor, then the resistance to push it back in place should be relieved (if it is the motor getting it stuck). however, looking at the wiring diagram for it, it could be the LIMIT SWITCH (SAFETY) that is malfunctioning, or one of the 3 relays (open, close, safety). |
#28 | |
dude jesus christ ITS SOMETHING MECHANICAL its cable fucking operated pulling it out wont do shit
ho ha ho chi chi |
#29 | |
nothing happened tried to see if it would close with the switch and even pulled it nothing. damn this sucks anymore ideas. |
#30 |
damn. im out of ideas
without being there its hard to figure this type of stuff out wait which way did you turn the nut? just loosen or to the right first?
ho ha ho chi chi |
