starting my ka24de build but need some info
my goal is 500whp
head supertech valves supertech valve springs supertech retainers cams --- not sure what cams to get need help block wisco pistons --- should get stock bore or over size if so how much eagle h beam rods acl bearing kit new oil pump new water pump turbo kit jgs turbo manifold sc61 turbo custom charge pipes presicion fmci tial 44 mm waste gate tial bov walbo 255 fuel pump 870cc injectors ecu--- not sure need help thats bout it is there any thing that i need or needs to be changed to safely get that hores power all info will be helpful |
#2 | |
![]() Join Date: Nov 2006
go standalone for your air/fuel management.
also, do yourself a favor and search instead of getting spoon fed on EVERY single forum you go on...
![]() Quote:
