Bee R Install on a 240SX S14 OBD1
Ok so I searched everywhere and there is no correct guide to install a Bee R Rev limiter on a OBD1 S14.
Does anyone here knows how to wire this? I just need the ECU pin#s Thanks |
#3 | |
Because on some threads they hooked up the ignition wire to the cas and some to the ignition switch. I just wanna make sure whats the right one |
