![]() Join Date: Oct 2003
TF Titanium 3" Custom Exhaust Dual Tip - Center exit
Our S14 is undergoing some major changes this year, so we are selling our Custom titanium center exit exhaust on the S14.
Up for sale is our custom 3" Center Exit Titanium exhaust system. Specs: Grade 2 Titanium 3" Inner Diameter .8mm wall thickness Dual 3" exhaust tip Entire Exhaust weight: 7.0 pounds! Bottom of trunk will need to be a flat bottom, or cut out needs to be made to allow the exhaust to reach the center. the exhaust has slip fit with spring tabs. Modified downpipe is also included! Downpipe has been shortened by 50% to allow for more titanium exhaust piping. It is a one piece exhaust. For shipping purposes, we can cut and flange the exhaust in the middle for an additional $175.00 $895.00 + shipping
![]() Join Date: May 2008
WOW!
thats definitely unique For 900 bucks, id expect nothing but mandrel bends, was that a prototype? it looks like there are some sharp pipe bends under the driveshaft. 7 lbs.. thats freaking light.
#3 | |
2. You cannot mandrel bend titanium. 3. you can see that the image I have posted are with tack welds by the trans for mock up. The bend behind the diff, you can see how smooth the angle is...
^it's Ti, you can't bend it.
cool exhaust, but i think an exhaust for cars that still have their fuel tanks is a bit more marketable. demo car is sick, chicago=best style.
#6 | |
The part that was removed is where the spare tire goes....
![]() Join Date: Oct 2006
Trader Rating: (163)
Uhhh, you talking to me? I never said anything about bending it!?!
But while we are on the subject, these guys say they mandrel bend titanium: tube bending,pipe bending,tube bending fabrication,exhaust tube bending,pipe bending fabrication,bent elbows,Woolf Aircraft Products |
![]() Join Date: Jan 2004
I work on aircraft for a living and our planes have sweet titanium piping with immaculate curvatures, but i have no idea how it was manufactured. If i could post a pic from here, i would.
I guess you you can mandrel bend titanium...
air plane manufacturers - makes sense. I'm sure it's a process that is different from steel. We tried - and failed. lol. We'll stick to pie cuts.
#21 |
Trust me you can bend Ti but if you stop your bend you better be 100% accurate because you cant bend it again. Work hardening will crack it. Hugely impractical to bend unless you have the $$$ to waste possibly thousands on Titanium piping if it's not right.
2008 350Z -- DD 1996 240SX -- Project |
#22 | |
