#122 |
![]() Join Date: Jun 2008
motor is in, heres some random pictures. my computer has been down
some stuff. staying t25 for now. still looking for a blown journal t28 for rebuild where can i order those lines?! made one side of the i/c piping out of rapper dans old shit haha dont get on my welds, i have a lincoln weldpack 100 with that fluxcore dogg trans mount is in also |
#139 |
![]() Join Date: Dec 2003
two things to tell you that will save some time.
First, SR's hate to have an atmospheric BOV that close to the TB without a SAFC; you will undoubtably have idle issues and run rich. Check your oil often for fuel diluting. And second, those gaskets that came with that exhaust manifold WILL NOT LAST! Buy the s15 7 layer and OEM collector. On another note, I respect the do it yourself attitude, and understand we all have different budgets, but there are things on there you choose to do b/c you want it now rather than later. this could look a lot better with more effort... But to each his own, you seem to like it so that's all that matters.
#140 | |
#142 | |
![]() Join Date: Dec 2007
BOOYAH! |
#144 |
wheres your s12? sell ti yet?
i think im gonna run no lights up front, just stock mk1 markerlights and grill. and have a bolt on foglight setup ill add when it gets dark. remember the car isnt driven much on the roads. just to some meets |
#146 |
lines are in (minus a missing oil feed banjo bolt)
i tapped into my upper elbow for coolant return used a 95 240sx oxygen sensor, i removed the "small hole" adapter which is and added a large hole adapter, (240 one) from a sohc manifold clips in, hopefully the wires are the same gotta loop heater core lines E Z clampz FTW |
#147 |
bought some cut steering knuckles from 180sx alan! they will be in soon
okayy, tying things up, picked up some parts spare fender, driveshaft, headlight cover (mine is dented), mk2 grill and marker light assembly got a battery cutoff at the local performance shop found a datsun symbol off a hidden pickup at the yard! mmn, it all fits under the hood! getting very close to startup |
#148 |
![]() Join Date: Dec 2008
dude. dude. dude. this car is TITS. i love evrything youve done with it. its perfect.
grip like roots, float like leaves. wtb s13 sus. |
#149 |
full pump assembly... done. lol
k heres my gangster ass push start. its adjustable, its on a clamp that i can slide back and forth, lol. just for now THIS connector i found in the bay has 2 thick gauge cables, ones black/white (for starter solenoid which goes to my button) and the other is white. im GUESSING the white 10 gauge wire is my alternator feed..? so ill be hooking that up with the same gauge wire to the battery? i dunno. im gonna run the car first, and remove the battery terminal. if it shuts off then ill know i was running on the battery which means my alt isnt working. heres the distribution block doing its job to all the main functions ive been hacking away at my screwed up stock harness for free wires. using the same color wires as the sr has. yes there is a jack in my door. it used to hold up my windows! |
#150 |
![]() Join Date: Oct 2009
dont kid about corrados. theyre great! lol its cool. I had a couple corrados now I drive a rps13. Dont get me wrong, Corrados are great....i just want a car that doesnt break! Get a nissan! hahahaahhaah
| build, drft, s12 |
