S14 suddenly stopped (won't start)
Hi,
I have a Nissan S14 SR20DET Blacktop from '95 LHD While coming home car suddenly died without hesitating..it simple stopped. Mounted the diagnose cable and it gave me Error Code 11... I replaced the CAS with a second hand one and the car started...it run ok for a couple of minutes and it died again...(car reached 50 degrees temp) Diagnose shows again Code 11 Any ideas what to check...? Code 11: CRANKSHAFT POSITION SENSOR CIRCUIT (0 STARTS AGO) Engine Mods: - downpipe + exhaust - FMIC - HKS BOV - piggy back ECUMASTER DET2 Nothing was done to the car for about 4 years..so everything worked ok |
I checked today the wiring of the cables and:
Wiring: CAS harness connector -> terminal B and ground => battery voltage CAS harness connector -> terminal A and ground => continuity exists harness connector and checked pin 42 and 52 -> continuity exists harness connector and checked pin 41 and 51 -> it displays 4.34 as resitance...is this normal? Unpluged CAS from the engine and checked the voltage: - one connection displays between 0.01 - 5 V - and the other one betweem 0.01 and 7v ...is this normal? |
