93 240sx helppppp
my indicator lights on my dash stay on when i take the key out and the windows still go up and down and the rear defroster works then if i hit the brake petal the radio and turbo timer turns on i pull the brown relay on the inside fuse box it stopes but then some shit dont work at all what the hell is causing this problem
I would like to think that you have a bad ignition since you still have power after the key is taken out.For the other problems i would say wiring have you done any wiring lately?
i had the same exact problem with my s14, i had to change the main harness w/ the fuse box on the interrior to fix it. The previous owner did a real hack job to the harness and fucked alot of shit up but that fixed it.
