Old 05-05-2017, 05:19 PM   #211
turtl631
turtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond reputeturtl631 has a reputation beyond repute
Ha, I'd be interested. Probably make my own otherwise.
S13, SR20 - Track day fun
turtl631 is offline   Reply With Quote
Old 05-31-2017, 12:40 PM   #212
Bushido
Bushido's Avatar
can I buy these yet?
Old 06-03-2017, 08:39 PM   #213
spray2020
spray2020's Avatar
spray2020 is an unknown quantity at this point
Here is my progress, I haven't really posted up much on here since I started. I mostly post on instagram.
I have re-done the prototype, with a bolt on upper bracket that is adjustable. Also snap on shrouds for the mini square morimoto projectors.
The problem I am having with everything is clearance. There is much much space for the projectors to fit and be adjusted- sans why I had to cut an opening in the core support for them to pass through. My goal is to not have to cut away any area that cuts away the factory mounting points for the pop-ups down below. However with the tight clearance, I had to cut away a lot around the upper mounting which basically turned that area into a thin strip. Granted I know that some people have tube front ends and would disregard this.
I am still working on them, but with other projects I am working on.. like a full custom sema car- this takes time to progress on.
Initial prototype pics off the car (before I printed the rear housing)
This is how the core support was cut (mind, my core support was damaged before, so I didn't mind cutting it. 89' coupe)
Fitted from the front:
Pics with the rear housing, and the shroud projector cut shorter (no need for the extra material as it isn't seen)
S13 Silvia Lip's f/s :www.codycasale.com
spray2020 is offline   Reply With Quote
Old 06-04-2017, 10:12 AM   #214
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
fucking neato!!!
supersayianjim is offline   Reply With Quote
Old 06-04-2017, 10:38 AM   #215
Bushido
Bushido's Avatar
It looks like the design is almost finalized.
Please let me know as soon as a finished product is ready to purchase.
Old 06-04-2017, 10:36 PM   #216
silviaks2nr
silviaks2nr's Avatar
Your projectors are upside down.
'98 240sx 5spd
Old 06-05-2017, 01:01 AM   #217
spray2020
spray2020's Avatar
Originally Posted by supersayianjim View Post
fucking neato!!!
Thanks
kind of, i'm still working on them!
Thanks for pointing that out, I honestly wasn't sure as I haven't illuminated them yet! Easy that I can just flip them around.
Old 06-05-2017, 08:05 AM   #218
tuzzio
tuzzio's Avatar
I can't wait to see them with covers on them. They'll look badass. Maybe finally these shitboxes will have efficient lighting
Old 06-05-2017, 10:27 AM   #219
ArtofSpeed
ArtofSpeed is an unknown quantity at this point
Interested in a set
ArtofSpeed is offline   Reply With Quote
Old 06-05-2017, 11:47 AM   #220
s13silvia123
s13silvia123's Avatar
Originally Posted by spray2020 View Post
Thanks
What kind of 3d printer are you using? Can you inform me so info with pro's and cons? I'm looking to buy one soon as well. Also,so have you ever charge clients for 3d printing yet? if so how for per cubic inch and the type of plastic you use?
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
Old 06-06-2017, 01:06 AM   #221
AscendaShogun
AscendaShogun's Avatar
AscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the roughAscendaShogun is a jewel in the rough
Honestly,
This is my favourite build thread.
Keep up the killer work.
SuperRadDriftyFranz
'88 S13 Silvia
decrepit teenage shitsleds
Originally Posted by LoSt180 View Post
"Cut my springs, car is bouncy, will a camber kit help?"
AscendaShogun is offline   Reply With Quote
Old 06-06-2017, 01:16 AM   #222
spray2020
spray2020's Avatar
Thanks! Same here I am hoping for the same
Originally Posted by ArtofSpeed View Post
Interested in a set
Cool
I am using a MakeiT INC 3D printer, Pro-L model: http://makeit-3d.com/
They are based out of California, and a pretty high end consumer printer. I used to work for the company, and now use one at my home.
Pros: You can make pretty much anything you can think of and 3d model! There are about 10-15 different types of plastics/ composites that it can print, including clear polycarbonate and a carbon fiber type filament. The size of the print is limited to the print area - about the size of a small suitcase.
Cons: it takes practice to get settings right, the prints can day a long time to print, prints can fail, Prints can take multiple tries to get right.
No, I don't take any personal jobs currently, but you can contact them (MakeiT INC) or other online based 3d printer websites who take on job's.
Old 10-02-2018, 07:02 AM   #223
adey
adey's Avatar
adey is an unknown quantity at this point
Any updates on this?? They look amazeballs.
adey is offline   Reply With Quote
Old 10-03-2018, 01:35 PM   #224
eagleeyes221
eagleeyes221 is an unknown quantity at this point
I don't think there have been any updates to this but i follow him on instagram and he is currently working on prototype S2000 fender vents. Ive been working on making my own set now for awhile and have yet to come up with a decent setup.
eagleeyes221 is offline   Reply With Quote
Old 10-04-2018, 12:05 PM   #225
go4speeed
go4speeed is an unknown quantity at this point
Sooooo siiiiick, always wanted a set, keep us posted.
go4speeed is offline   Reply With Quote
Old 10-07-2018, 07:05 AM   #226
go4speeed
What's you IG?
Old 11-21-2018, 11:28 AM   #227
spray2020
spray2020's Avatar
I am still working on them. Just need to do other projects as well to pay the bills. Plan to do some work on them over this holiday weekend. Will have updated photos.
