#1651 |
![]() Join Date: Sep 2005
You know?, I thought it was understood that check timing meant with a light!
I mean timing is critical, so why wouldn't you?! And I guess some of the published articles don't really tell you, that if you, stab the cas and as the FS states, the engine will start, but you might not be at the correct timing. How many times have I said check timing? hmmmm! What do they do, just look at it and say timing is spot on?
#1652 |
cody - i will roll the motor over to compression on #1, line up my timing chain marks, and make sure the crank pulley is on second notch from the left.
i pull the CAS, line up the marks on it and stick it back in there? then look for what exactly? i know they gears rotate a bit but maybe its going to far. |
#1655 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
Well that's just the thing...the car won't blow up at 13/14 or 16/17 either...sure performance can be effected, but for the most part, on lower power, most people won't seen any issues. Maybe loss of power, but it's hard to say. Only so much timing you can take advantage of before it becomes harmful. Quote:
#1656 | |
![]() Join Date: Mar 2006
2fast4you....I just re-inserted my CAS this weekend....as you put it in and the gears grab, the CAS rotates clockwise, toward the back of the car. I started it off with the rightmost dot aligned with the line....and had it oriented such that the plug faced almost vertically up. Initially, this looks wrong, because the slots don't line up with the hole for the bolts....but as it goes in and grabs, it naturally rotates clockwise....and winds up roughly in the middle of the adjustment range, like Cody said. I did it like this without even being able to see (valve cover on) and then hit it with the gun and it was at 14*....pretty damn close
![]() Daily driven |
#1657 |
see when i do it as stated above, i have to rotate the cas a little bit...
also, kinda off topic of this thread but since you both are here(cody and jspeath)...il just pm you guys and leave it out of this. easier that way. |
#1658 |
#1659 |
you should only tune/expect to tune with what is readily available to you. i mean, if you can afford to run c16 and buy it in advance, then do it!
c16 smells good, specially when it burns ![]() |
#1662 |
![]() ![]() ![]() Feedback Score: 7 reviews
I've been following this thread for a while and figured I would post this up. Maybe I could get some answers here.
This my dyno graph from when I had my 2871r car dyno'ed about a year ago. I had lost the graph until now. I've very curious as to why the graph gets so choppy after 5.5 and why the torque dives so fast. I thought it might be timing in the tune. But to be honest, I have no clue. I checked base timing before dyno and it was spot on. There were no boostleaks or anything of the sort. Afr's were 11.3-11.6 under boost. Made 336 hp/ 326 torque Mods: S13 Blacktop SR, great compression GT2871r @ 19psi Enthalpy tuned ECU BC 264's Stock Intake Mani Silkroad tubular turbo mani Sard 850cc Brand new NGK Bkr7e gapped at .027 All other supporting mods. I'm probably leaving some stuff out, but maybe you can shoot me some ideas. Thanks
#1663 | |
Yeah something seems definitely off there. It could maybe be the intake manifold......I went back and looked at my old dyno plot, and the torque dropped off similarly early as yours....but that was with stock intake manifold and stock cams. With the BC 264s, you would think that maybe your "drop off point" would be later, but your torque is def dropping off pretty early....
#1665 |
I agree on the last posts for that Dyno.. I made the same power on my SR on Greddy T517z, 550cc, Z32 maf, Nistune, Stock I/E manifolds and stock cams @ same boost levels.. Cams should help increase top end but this case not sure what's going on for your power is falling off way to early. It's possible to boost controller is not able to hold it or you should consider sending Scott @ Enthalpy an email for a possible re-tune. GL!
#1666 |
You guys are forgetting the infamous flavors of the gt2871r, aka 48 and 52 trims.
power output looks like a 52trim and appears to be normal. If you had stock cams and intake and pushing about 17psi!
#1667 |
Thanks for the all the replies.
Boost is staying solid all the way to redline and I am using the 52 trim gt2871. My concern is not the power, but why the graph is so choppy and torque drops so fast. I am very unfamiliar with tuning. Could there not be enough timing past 5.5k? I understand that I am using a generic rom tune for my 2871r, but if it works fine for everyone else, I wonder why my graph would look like that? I hoped that made sense.
#1668 | |
![]() Join Date: Jul 2008
15lbs on a a 52 trim .64AR 2871r. HKS 256/264 cams, and Power FC. I guess I'll find out when I get this boost leak fixed, but just curious as to what I'd be looking at. 550's don't have much room left (90% Injector Duty) hence the low boost. |
#1670 | ||
If your on a budget and looking for 300hp, completely skip gt28rs, gt2871r 48trim, and get the s15 turbo, or the gt2560r or the s15 spec R! lol! If your willing to go top-mount your world just gets better and a little cheaper vs the initial modification. MHO!
#1672 |
![]() Join Date: Dec 2009
New gt2871r user
Finaly finished the install of my new setup (old setup was stock S14):
GT2871R .86 (.56 trim) @ 1.2 bar = 17.8 psi Deatschwerk 740cc Z32 maf 3" exhaust JWT ecu Stock s14 sr20det block (VCT disconnected true huge rattle) Thoughts so far: Thing is laggy. Looks like peakboost sets in at 4800 ish rpm (haent done boostleak test and for some reason my profec type-S cant get it over 1.2 bar... the notch wont go any futher haha). ..but when it finaly kicks in it kicks good. raced against my friends rb26 @.8 bar S13 and it was a draw. By the datascan voltage and dutycycle (4,4V & 68%) I'll guestimate a 330whp ish at the moment. Anyway, def want to get the lag down and want more boost than 1.2 bar. Cams and intake seems to be the next thing to get (and some dyno time ..). |
#1673 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
Curious about a reccomendation...
I was told by a pretty reputable guy to run a 0.8mm Apexi MHG for my setup in order to boost a minimum of 1 bar. here's my setup (pretty common): 2871 .64 256 poncams 850cc injectors greddy int mani SS ex mani PFC d-jetro All other supporting mods (motor compression is perfect) I see alot of people running the 1.2mm size gasket. I am just wondering why he said to run a 0.8mm MHG as opposed to 1.2??? I don't plan on decking the head or anything. Anyone have any input/guidance as to why possibly?
#1674 | ||
Trader Rating: (58)
#1678 |
I have a question for you. Why would a MHG make it safe to run 1bar?
There is a list of yes and no's to your question, for example. No, if you're using 87oct and 370cc's! Yes, if you are already running 13.6psi and a 2871r! No, if you don't have a gauge that reads in bar!
#1679 | |
Trader Rating: (81)
They don't want something to happen and then me give a bad rep to them.Thanks though!
