![]() Join Date: May 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
One set of new Toyo RA-1's for cheap!
A SET OF FOUR 205/50R15 TOYO RA-1'S FOR $500!
Only one set in stock and it will not be parted out. Local pick-up is welcome and we can ship too for an extra charge. Unit is brand new and never rolled on. Most places sell these for an excess of $550 for a set. Here's a little something from Toyo's brochure literature. If you have any questions, please feel free to let me know! Thanks. ![]() The performance-proven RA1™ features high-tech components to provide an uncommon advantage to the cost-conscious competitor who still demands quick lap times. It’s true performance from Toyo! General Proxes RA-1 setup guidelines: Operating Temperature: 140°F to 220°F, optimum around 200°F Hot Inflation Pressures: High 30s to Low 40s (psi) Camber: -2.5° to -5.0° Caster: As much positive as possible Click here for recommendations for proper use, handling and storage of this tire in colder climates. Features and Benefits Competitive Handling Soft but durable tread compound Advanced race-proven casing design Two steel belts Spiral wound cap ply (construction may vary by size) Steel wire reinforced sidewalls (construction may vary by size) Steering Response Heavy-duty bead construction Steel belted construction Steel wire reinforced sidewalls (construction may vary by size) Wet and Dry Traction Stepped tread design Tread depth can be shaved to maximize dry traction Full tread depth of 8/32nds provides aggressive wet traction Treadlife Steel belted construction Treadwear Warranty Information (ask your Toyo Tires Dealer for details) Workmanship & Materials Additional Information UTQG 100 AA A |
Always bringin the hot deals on tire pricing! Good seein you and the wifey yesterday Brian!
PS don't forget to come get your Carbing strut tower bar ![]()
***PLEASE NOTE*** I am no longer affiliated with West Covina Nissan. |
