Old 08-27-2004, 12:12 PM   #1
rabid_monkey
rabid_monkey can only hope to improve
Something in my Suspension is driving me crazy!!!
so something in my rear left suspension area is making this crazy clunk sound. almost like something is compressing, and getting stuck, then popping back out... distinctly different than diff noise, and only rear left. If you yank hard on the axle OR press down on the back of the car... when the car raises back up u hear this "clunk clunk" and/or creaking noise like an old door. When there is no weight on that wheel, u cant do anything to make the noise. It also makes the noise when ur driving, and u let off the gas to shift gears and the car shifts weight forward. It did it forever, but now its getting worse. Nobody can figure it out. All my arms are tight, nothing is loose, Ive checked and double checked. Here are my suspension mods:
- Cusco Zero2 coilovers
- Cusco front and rear strut bars
- Suspension Technique front and rear sway bars
- Dupree subframe spacers
- DGTrials traction arms
- Tein inner/outer tie rods
- Project Silvia RUCAs
- SPL toe arms
- SPL tc rods
good luck, cause Im stumped... please help!
rabid_monkey is offline   Reply With Quote
Old 08-27-2004, 12:19 PM   #2
BSeay
BSeay's Avatar
BSeay is an unknown quantity at this point
Send a message via AIM to BSeay
Maybe your coilover is blown? Just a guess maybe you should have it checked out or rebuilt?
1995 240SX SE - Sold
BSeay is offline   Reply With Quote
Old 08-27-2004, 12:21 PM   #3
nlzmo400r
nlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nicenlzmo400r is just really nice
Send a message via AIM to nlzmo400r
sounds like your spring is coming off of the spring perch. Perhaps it wasnt seated properly?
nlzmo400r is offline   Reply With Quote
Old 08-27-2004, 12:33 PM   #4
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
My front right AGX is blown and doing something very similar to what you described.
LanceS13 is offline   Reply With Quote
Old 08-27-2004, 02:47 PM   #5
gmckey
gmckey is an unknown quantity at this point
Send a message via AIM to gmckey
I have the same problem or at least very similar, whenever I change load on the drivetrain (ie: let the clutch out or push it in while moving) I get a clunk like something knocking back and forth.. I first noticed it after installing my RUCA's and subframe spacers the same day... I went up to SPL Parts and Kuah and Rich looked over the car and their analysis was slop in the VLSD... while I'm not sure that that's what it is, there's no other option besides a loose axle that I haven't checked yet.
my mods:
SPL KTS coilovers
Cusco Sways/RUCA/tension rod bar
SPL subframe spacers
gmckey is offline   Reply With Quote
Old 08-27-2004, 03:00 PM   #6
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
One major thing you might want to check is the lower control arm. My car was clunking everytime I stopped because my tension rods were ready to come off the LCA.
-Juan
240Stilo is offline   Reply With Quote
Old 08-27-2004, 03:03 PM   #7
Red
Red's Avatar
Red is an unknown quantity at this point
I also have this issue in my front right...
I guess I should shake some things in there to see if anythings loos.
http://www.cardomain.com/memberpage/509537
http://www.imagestation.com/album/?id=4287415487
#/f/showthread.php?t=21036
Red is offline   Reply With Quote
Old 08-27-2004, 03:27 PM   #8
Brian W.
Brian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfectionBrian W. is close to perfection
Send a message via AIM to Brian W.
tommorrow!!!!!!!!!!! we fix
www.ma-motorsports.com
-Fab work, builds, swaps, dyno tuning
Brian W. is offline   Reply With Quote
Old 08-27-2004, 04:06 PM   #9
gmckey
please post the solution if you figure it out!
Old 08-28-2004, 11:12 AM   #10
rabid_monkey
thanx guys for things to look out for. yea, i either thought it was the RUCA about to break (happened to my friend with same Project Silvia ones) or something wrong with the axle. The shock doesnt seem to be blown at all. Its been doing this for a long time, it just got worse like the past week. Going up to MA in an hour to try and get it fixed.
I'll post up wut it was after we are done.
- Collin
Old 08-28-2004, 11:26 AM   #11
dvdevo
dvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enoughdvdevo will become famous soon enough
mine clunks on the rear passenger side. i think it might be my coilovers(d2). I tried tightening the top bolt but the bolt didnt really move. Can't be my ruca's because i just installed new adjustable ones.
dvdevo is offline   Reply With Quote
Old 08-29-2004, 01:32 PM   #12
rabid_monkey
ok here it goes fellas... sollution found.
Thanks to Brian and Ray from MA-motorsports.com for all their help. I went up to their shop in Towson, MD to try and figure it out (me and brian spent like 40min trying another day). The problem was u could feel the clunk in every arm equally. So this time, Ray gets under the car with a stethescope and listens to every single bolt and joint as we bounce it up and down for like 20 minutes. the verdict:
shitty ass craptacular heim joints in the Project Silvia RUCAs are getting stuck and are corroding (sp?). So these will need replacement. We greased them up more, but it berely helped. Also, I heard Project Silvia has no customer repore (ie. one of my other friends RUCAs broke and they basically told him tough luck), but Im gonna see if they will send me a replacement. Hopefully they arent whores.
Also, the DGTrials heim on the toe links were berely starting to stick too, a slight sound in comparison to the crazy clunk from the RUCAs, but I called my friend Matt Petty from DG who was heading up the production of these arms and he is replacing the heims for free, with a lifetime warranty. So atleast that one is done and done, and easy to deal with. I love good companies that care about customer satisfaction.
So... in conclusion, I hate these piece of crap RUCAs, but I dont wanna spend $300 on new ones, so... if Project Silvia wont replace the heims, Matt at DG will give me new heims for the RUCAs as well as the toe links. hope this helps anyone out with similar problems... get a stethescope. Thanks again to ma-motorsports.com ... awesome dudes.
Old 08-29-2004, 04:08 PM   #13
theicecreamdan
are these for an s13 or s14?
a friend of mine is gonna be fabricating some adjustable RUCAs for me pretty soon, the first set he's gonna make will be for s13, but after that s14 RUCAs will come soon, and he won't be using crappy heim joints
theicecreamdan is offline   Reply With Quote
Old 08-29-2004, 05:36 PM   #14
S14DB
AFC #1
S14DB's Avatar
Ebay sells crappy heim joints in bulk. Just buy a bag and swap. Cheaper than upgrading
Old 08-29-2004, 06:55 PM   #15
rabid_monkey
S13.
also, Ray from MA says that the reason these suck and corrode is cause their made of shit, and most companies dont wanna use Cro-moly heims cause they cost like 5 times as much as the regular kind. Just a thought. Maybe I will buy a bag of heims for cheap, something to consider.
Old 08-29-2004, 11:24 PM   #16
thx247
thx247 is an unknown quantity at this point
Lol crappy rod ends...I hate those things. Just so the rest of you know, this is where those ruca's and TC rods and all that other stuff you see on ebay get to be so cheap. They save money on the heim joint/rod end. High quality rod ends cost decent money, but the savings are measured in alignments.
http://www.aurorabearing.com/
This place too
http://www.racerpartswholesale.com/roden1.htm
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
