I cant seem to find a wiring diagram for a KA24E's distributor. I need to test for a short in the crank angle position sensor since im not getting spark or fuel. The colors on the harness side are blk, blk/wht, grn/blk, and grn/ylw. I was wondering if anyone has either found a diagram or can tell me what color corresponds to what. Thanks
Ive done a little more digging into the FSM and found that B and G/B are grounds while G/B runs to the ECU pins 22 and 30. G/Y Also runs to the ECU pins 31 and 40 and B/W runs to ECU pin 47 and the ECCS Relay.
