Old 04-19-2011, 08:40 PM   #1
ricky33183
ricky33183 is an unknown quantity at this point
Just got a 95' 240sx need advice
i got a 1995 s14 LE this weekend but it needs minor work, Will a s13 sunroof fit my 95? am just talking about the glass and weatherstripping
ricky33183 is offline   Reply With Quote
Old 04-19-2011, 09:26 PM   #2
Sileighty_85
Sileighty_85's Avatar
ummmm No
two totally different chassis
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-20-2011, 06:46 PM   #3
ricky33183
Originally Posted by Sileighty_85 View Post
ummmm No
i already got the answer but thanks !
Old 04-20-2011, 06:49 PM   #4
ricky33183
here are some pics i took today after installing a new air filter
what do you think?
Old 04-20-2011, 06:51 PM   #5
theboy
theboy is an unknown quantity at this point
im curious, how much did you pay for it?
theboy is offline   Reply With Quote
Old 04-20-2011, 06:54 PM   #6
squatting pigeon
squatting pigeon's Avatar
squatting pigeon is an unknown quantity at this point
looks good! time to go lowerrrrrrrrrr
squatting pigeon is offline   Reply With Quote
Old 04-20-2011, 07:00 PM   #7
ricky33183
exactly what i first thought
should i go with shocks and springs for now or wait and get coilovers?
Old 04-20-2011, 07:01 PM   #8
ricky33183
take a guess its an automatic and has 97k miles
Old 04-20-2011, 07:02 PM   #9
squatting pigeon
Coils are soooooo Worth it, because you'll get to control 100% of the ride.
I'd save for coils
Old 04-20-2011, 07:07 PM   #10
ricky33183
I'd save for coils
thanks i will do that. Do u think my first mod should be a 5 speed swap?
Old 04-20-2011, 07:08 PM   #11
97nismo
97nismo's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
the flip up glass outta s13 will fit seen it a couple of times............tight fit though
Feedback:
#/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 04-20-2011, 07:11 PM   #12
squatting pigeon
well, I bought mine as an auto, but immediately threw in an s14 SR after a month of driving it lol
I'd make sure the Timing chain guides have been removed then go for the 5 speed swap and have some fun with it
Old 04-20-2011, 07:24 PM   #13
ricky33183
Yea the chains touching the guides and making the common timming chain noise lol, am going to remove the top and side guides and also change the head gasket.
Old 04-20-2011, 07:31 PM   #14
ricky33183
was it the manual or power sunroof?
Old 04-20-2011, 07:32 PM   #15
squatting pigeon
good dealll I jsut bought my wife a zenki a month ago and the chain guide had been sheared off and was bouncing around under the valve cover...
you gonna do a 5-lug swap eventually?
Old 04-20-2011, 07:47 PM   #16
ricky33183
yea but the 5 speed swap first, its such a pita to find 4 lug wheels
Old 04-20-2011, 07:53 PM   #17
ricky33183
I have rust in the radiator the previous owner was running straight water >.< can i use a radiator cleaner and flush it or should i get a new rad and pump?
Old 04-20-2011, 07:53 PM   #18
squatting pigeon
there ya go, im interested in seeing how this things gonna go! keep updating
Old 04-20-2011, 08:13 PM   #19
squatting pigeon
youre most likely going to need a new water pump because the rust is probably from the fins, but the radiator should be OK with a good flush, just make sure you flush it all before you replace the water pump
Old 04-20-2011, 08:25 PM   #20
ricky33183
thanks il take pics tomorrow of the rust. My sunroof needs the weatherstripping but it doesn't leak. can i just buy the weather stripping or do i need to buy the whole glass part which comes with the weather stripping like my local 240 specialist said?
Old 04-20-2011, 08:29 PM   #21
squatting pigeon
it depends if you have the clips all around the sunroof, they are an off white plastic looking thing, and if you dont have them... you'll most likely have to buy the whole glass, or try and 'jerry-rig' something. keep in mind the weatherstripping is ridiculously expensive.... but it can be bought separately, try courtesyparts.com
ive had my 240 for a year and a half and havent had the weatherstrip on it at all
Old 04-20-2011, 08:34 PM   #22
ricky33183
thanks, wow a year and a half, does it have any rust?leak?
Old 04-20-2011, 08:36 PM   #23
squatting pigeon
it leaks a little when it rains, nothing crazy... but going down the highway the wind noise is annoying, so i just leave it up at an angle. and no, no rust none of the water pools up enough to rust. the car sat in the lady i bought it from's driveway for a year, so it probably hasnt had trim for 3+ years
Old 04-20-2011, 08:41 PM   #24
ricky33183
mine has a little rust but i have it taped up until i find weather striping
Old 04-20-2011, 08:43 PM   #25
squatting pigeon
thats good, it will keep out the wind noise, and water until you get some strip, its an easy install too if you have the clips!
Old 04-20-2011, 08:57 PM   #26
ricky33183
i have my fingers crossed to have the clips il check when i change the tape
Old 04-20-2011, 09:00 PM   #27
squatting pigeon
Good luck bro! haha
its a 50/50 shot
Old 04-21-2011, 06:25 AM   #28
97nismo
97nismo's Avatar
Trader Rating: (53)
manual glass sunroof i have a pic of one somewhere............i would go to a junkyard and find an s13 and measure but i personally have never done it just seen it
Feedback:
Old 04-22-2011, 10:18 AM   #29
ricky33183
i just fixed my ac which was working on only level 4
lol check out the old resistor, pretty nasty huh?
my 240 smells like gas outside when its running, the previous owner said he cracked the gas tank and put in a new one, also the fuel gauge doesn't work it stays near empty and barely moves when i put gas in, i just wait for the gas light to come on to fill her up
does anyone have any tips to fix this?
Old 04-22-2011, 10:25 AM   #30
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
Your fuel sending unit is bad. I have one for sale if needed.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
