![]() Join Date: May 2011
SR20 IACV, Ignitor, A/C compressor, KA-T manifold, etc
All prices are for parts picked up, shipping is extra and is available on basically everything but transmission.
OEM parts are off of a rust free 1992 S13 hatch. Only trades I'm interested are SR parts oem or aftermarket. (o2 elbow, downpipe, test pipe, intercooler, bov, oem or aftermarket SR intake from turbo to maf) All parts are in the Dayton Ohio area. Make offers SR20DET Ignitor chip. Was taken off of a working car, looks to be in great shape. SOLD S13 SR20DET IACV. Was working when taken off. Tested with a power supply and both valves work. Idle screw is a little dicked up but isnt stuck and turns freely by hand. SOLD S13 redtop SR20DET A/C Compressor in really good shape. $25 ![]() ![]() ![]() SR20DET OEM nissan valve seals. Intake and exhaust. Bought in a full gasket kit for a Redtop SR and didn't need to use them. $15 SHIPPED ![]() S13 Hatch tail lights and lower metal trim piece. Only missing 1 bulb. In very good condition, has one small crack on the right turn signal section. Center piece has what looks like a crack but its internal and there isn't a crack in the plastic. $45 for all of it or in pieces (metal lower trim $15, middle lights $20, each side $15) KA24DE bottom mount T25/T28 manifold. Identical to the Megan one on FRSport, has stronger supports welded on than typical Ebay manifolds. never used. no gaskets. SOLD S13 dual cam TPS. should work for OBD1 s14s too. works great. $15 shipped SR20 Transmission without bellhousing. Can be used with KA bell housing or CA or SR. I was told the second gear synchro started to grind a bit. Keeping the SR bellhousing and using my KA transmission when I swap. $100 You can reach me by text at 937 470 1704 Last edited by rpierce; 02-06-2014 at 05:12 PM.. |
