![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
SR20det goofy injectors and running rich
I just bought an Sr20det redtop (with coilpacks idk if that makes a difference) hatchback, and it runs a little rich.
I went to change my plugs and noticed that cylinders 1 and 2 use red injectors and cylinders 3 and 4 were using a light purple injector. once i pulled the spark plugs it was obvious that this was atleast part of the issue Spark plug 1 and 2 had light carbon build up and cylinders 3 and 4 had excessive carbon build up that left everything black on the tip of the plugs obviously i need to get a set of matching stock injectors but it almost looks like the red low flow injectors might run at a better fuel ratio, but my fear is that when it gets into boost it might run lean I Know the purple are the stock 370cc ![]() ![]() Last edited by kyral; 12-31-2015 at 05:48 AM.. |
