![]() Join Date: Feb 2010
Suspension install
Ok Im planning to buy a complete suspension kit including
X2 SILVER REAR LOWER CONTROL TOE ARMS X2 SILVER FRONT TENSION RODS X2 SILVER REAR TRACTION ARM RODS X2 SILVER REAR CAMBER KIT X1 SILVER REAR SUPPORT BAR X2 Sway bars I would like some help on how to install myself guides would be nice Thanks |
![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
Grease the bearings. Use PB blaster (Broke a bolt when I did it w/o it on one side). Just adjust it to oem try to eye it. Then take it to alignment shop to whatever spec you wanted for your wheels. If you're looking for a write up just look for it but it seems pretty straight forward.
Weeee!~Coupe love <3
