240sx HB ka24de itbs fender flared freshness *BUILD PIX* so far...
i bought the car in nov 2008 for 2000 bux,came with stiock supspension, ca18det running on megasquirt, untuned, t28, fmic wheels, and sil front; in boca raton.
![]() ![]() -tuned at zfever by martin.223whp at 7 pounds ![]() ![]() -spun bearing during first hour of sliding the car after gettring fresh tune and installing welded diff; oil press gauge wasnt hooked up, oil pump failed. ![]() -car sat around for awhile (and i mean SAT around, waiting for coils) while i parted out turbo setup motor wheels sil front exhaust ![]() paint time ![]() playground green walmart house paint ![]() clear coat ![]() -cwings fender flares kevlar/cf mix with eagle hameerheads 15x8 -70 wheels 1955015 tires ![]() wheels were given to me by a friend for 100 bux, started out as a i-dare-u-to-run-these wheels thing lol, monster truck tires included ![]() perfect widebody flushness achieve with rucas and a little neg camber ALL AROUND ![]() lots of werk *****zzz ![]() ![]() takin a break, nice seat in the dish, u try that with ur +35 wheels buddy lol smoke session hahacustom ca crank pulley lengthened for ka application, trigger wheel for megasquirt pressed on ![]() TRIGGER WHEEL SENSOR GETTO MOUNTED FOR NOW ![]() MAP SENSOR PLUGGED INTO VACUUM SYSTEM FOR ITBS/INTAKE MANIFOLD/BRAKE MASTER ![]() itbs assembled with home depot plumbing couplers and chopped ka intake manifold, decent header ![]() paper towel in oem distribuotr location, ignition coil ford edis 4 installed under dash, follow wires thru firewall ![]() and now PRESENTING! ![]() ![]() ![]() ![]() in the skreetz! UKNOWHOWWEDO gettin tuned now at zfever again this week. HOPEFULLY I CAN MAKE OSW THIS WEEKEND.TRING TO FINISH PAINT TWO TONE WITH BETTER FLAKE.AND I NEED TO MOUNT SETAS IN. THATS IT. LET ME KNOW WHAT YALL THINK. PEACE. SINK ILL BE OUT SLIDING IN A CITY NEAR YOU AGAIN VERY SOON : ) SHOUT OUT TO NEIGHBORHOOD BASER/CRACKHEAD FOR WORKING FOR ME. PAINTING MY WHOLE CAR SHINING MY RIMS AND DOIN THE CUTTING FOR CUSTOM ITBS ![]() ![]() |
![]() Join Date: Sep 2005
Trader Rating: (48)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 48 reviews
Looks like a cool set up, is it running ?
What #s are you going for as far as power/future plans ?
![]() Do you suffer from vaginal dryness... |
it runs but it is in need of a serious tune to drive it. should be gettin tuned at zfever this weekend. ill be happy with like 180-190whp for now.then i will begin to beat the hell out of it in florida drift events. eventually i will start building a high comp bottom end for more power and reliablility
![]() Join Date: Oct 2004
i hope you have aftermarket cams and high compression pistons if you plan on getting anything near 190 hp. a couple years ago there was a guy on here who had your exact setup on a KA and he made like 168 hp.
![]() Join Date: Sep 2006
How about getting your crackhead some glasses? Last time I checked eyes weren't cheap.
Looks like the car is coming along. I would like to see what kind of numbers you make on that KA. It looks like a pretty sweet setup. Good work.
1997 240sx SE 1998 Frontier SE 1990 240sx Coupe - Sold 1992 Talon Tsi - Sold |
im gonna throw in an extra oem ex cam on the intake side for now, im gonna be rebuilding another motor on the side with sohc pistons and headwork in the meantime.maybe get some stage three cams too.
hahahaha he shot dope in my bathroom too shortly after this pic was taken.it gives em lotsa energy to werk harder. did i mention he painted my car too, in a ddition to shining the rims and cutting manifold lol
