S13 wiper wiring
I have a 90 240sx with sr20, the wipers do not work at all I was looking for a wiring diagram for wipers with intermittent I have the tcu and the green wiper box, I know everything from the engine side of the smj is there wiring wise, I had been going threw the wiring and removing wiring I didn't need such as
Things removed:
Electric seatbelt wiring
Ebrake wiring
Consolt port
Ac wire from ecu
hatch interior light
Speaker wiring
Door chime
diode that's under dash
Everything worked before hand and the only not working are the wipers now I've looked through the fsm and can't see that the wipers tie into any of those things and from searching the forums I can only find things for a s14 I'm looking for a wiring diagram to get them working again and I would like to keep the intermittent, or something I'm not seeing in the fsm that shows that it did tie into one of those
Originally Posted by ixfxi
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
