Old 09-30-2009, 08:04 PM   #1
Ambush
Ambush is an unknown quantity at this point
SR SR20 HELP! (video included)
i have NO idea what is wrong with it.
at first i thought it was the ecu. i tryed another ECU (red top) everything is still the same.
in the video, the popping sounds and stumbling sounds are backfires.
the car struggles to go pass 3000 RPM.
my turbo spools up to quick, and it just stays at boost.
its like im only getting 50HP.
http://www.youtube.com/watch?v=QvQFe...lepage#&fmt=18
http://www.youtube.com/watch?v=B9zM_...channel&fmt=18
Ambush is offline   Reply With Quote
Old 09-30-2009, 08:10 PM   #2
chrissyPOO
chrissyPOO is an unknown quantity at this point
have you tried swapping out your MAFS for a known working one? maybe your car is in limp mode and dumping lots of gas
chrissyPOO is offline   Reply With Quote
Old 09-30-2009, 08:11 PM   #3
charlie321
charlie321's Avatar
charlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfectioncharlie321 is close to perfection
Send a message via AIM to charlie321 Send a message via MSN to charlie321
check your MAF
charlie321 is offline   Reply With Quote
Old 09-30-2009, 10:23 PM   #4
SleepR 240sx
SleepR 240sx's Avatar
SleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond reputeSleepR 240sx has a reputation beyond repute
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
MAF...check ECU for codes...vaccuum leak
This is zilvia. We aren't nice.
Quoted For Truth
Check out the coolest new thing: toddrickkkkk.blogspot.com
SleepR 240sx is offline   Reply With Quote
Old 09-30-2009, 10:50 PM   #5
s13silvia123
s13silvia123's Avatar
boost leak check for that
Old 10-01-2009, 12:14 AM   #6
Ambush
i've changed the MAF. tryed a red top & black top ECU.
Old 10-01-2009, 12:06 PM   #7
SleepR 240sx
vaccuum leak will cause you to run pig rich and give you major trouble revving....check all your lines...10 bucks says you've got a leak somewhere...check IC piping/IC...everything...it's there somewhere
Quoted For Truth
Old 10-01-2009, 09:26 PM   #8
Ambush
bump
ughhhhh -__-
Old 10-02-2009, 12:15 AM   #9
SleepR 240sx
bump
ughhhhh -__-
? What else do you want. We've given you a list of the most likely causes. Go check over every square centimeter if you have to.
Quoted For Truth
Old 10-02-2009, 12:24 AM   #10
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Hows your CAS timing? Too retarded will cause the turbo to spool up quick and your car goes nowhere. Happened with my friends redtop, we turned the CAS almost all the way clockwise and it ran like a champ after that. But it sounds like a combination of that + vacuum leak somewhere.
