![]() Join Date: Aug 2005
Oil cooler, Koni, SOHC HUD cluster etc
I'm trying to clean out my garage before I move, so here goes.
S13 front struts w/ Koni yellows and modded spring perch for GC coils(by Veilside180sx), powdercoated silver SOLD: Oil cooler core, bought and never used SOLD: SOHC HUD cluster w/ harness SOLD: S14 OEM tension rods $15 shipped I will be adding more things so keep checking back. Last edited by fromxtor; 07-24-2008 at 11:48 AM.. |
Yes it is a Long oil cooler,the size is 1.5x11x5.5" and has 10-8 AN step down fittings in it. So if you got #10 AN straight fittings you could use #10 AN lines.
![]() Join Date: Nov 2004
Quick question on the Konis, those aren't short stroke dampers right? So they won't go terribly low on GC coils without killing the suspension travel?
they are the Koni sports:
Why the industries first adjustable shock is still the best: * Big handling improvements * Reasonable ride quality * External rebound adjustment on most cars * Best KONI shock for all lowering springs * Re-buildable and re-valveable for custom vehicle setups * Yellow exterior finish * Lifetime Warranty Personalize your car's ride/handling with these precision damper units http://www.koni-na.com/sport.cfm |
Just one more question, they're adjustable right? The Koni site says most applications are adjustable so I wanted to ask. If not, what's the valving like? I.e. approximately what spring rates would be the best match?
Thanks, sorry for all the ?s ![]() |
Seeing as these are my old struts, I feel I can answer this one. Yes, they are adjustable, if you look at the top of the strut shaft you can just make out a yellow adjuster. For valving, let's just say you could run spring rates up to 450's without needing a revalve, which is more than enough for a street driven car that see's the track.
Thanks, I appreciate it! =D
