SE-R Spec-V Brembo Front Calipers & Rotors - $375
04 SE-R Spec-V Brembo Front Calipers & BNIB 4x114.3 Spec-V Rotors
These calipers are a direct bolt-on to any S-Chassis, no brackets needed. $375 Shipped Located in Dallas, TX ![]() ![]() ![]() |
![]() Join Date: Feb 2014
I have sent you a pm good sir. Also could you measure the distance from the face of the mounting bolts to the outside edge if the caliper. I'm trying to see if my riverside altsdats will clear these
