1989 Nissan Silvia
1989 Nissan Silvia
Located in Las Vegas, NV. Rebuilt CA18DET with probably less than 2000 miles. No dents, RHD JDM AF straight from the motherland, and paint is one color. Not the best shape, but better than a lot of the 240s in Vegas. Lost interest in the car scene. Been sitting in a garage for the last year. Not registered. Clean title. Get a truck to pick it up. Engine rebuilt by HBR. Block/head decked. Cylinders walls honed. Engine/Transmission: CA18DET Nismo Motor/Trans mounts 256/256 Tomei Poncams JE Forged Pistons Cometic HG R33 GTR Intercooler Clevite Main/Rod bearings Custom Tubular Manifold HKS Turbo Adjustable FPR 256lph Deustchwerks fuel pump 444cc GTR injectors Tial BOV Custom catch can OS Giken Twinplate Suspension: Cusco Front Tien Rear Boxed LCAs Nismo strut bar Nismo Tension Rods (probably should get new ones, rubber bushings have cracks) VLSD Rear Camber Arms Exterior: OEM Aero K's Front Dmax Sides Dmax Rear Dmax Roof Spoiler Prelude Lip (needs to be remounted) 17" Nismo LMGT3s, not in the best shape but new tires Interior: Full interior Recaro Half Bucket driver S14 Passenger Start Switch Panel Not super destroyed dash Momo Steering Wheel Water/Oil temp Defi gauges not wired in Other: HKS FconV ECU (Old gen) HKS EVC Boost Controller AFR wideband (not installed) New steel braided clutch line New braided power steering lines New OEM gaskets/seals Bad: Few rust spots here and there Someone tried stealing the car and broke the turn key, so its on a switch panel (not necessarily bad, but just thought id throw that out there) No AC Needs tune Got the BOV welded too close to the engine bay fuse box, so the fuse box is loosened and moved to the side. Prob needs a new slave cylinder. Runs great, pulls hard. A bit rich, but probably needs timing adjustments/tune. $7000, No trades. No lowballs. *SOLD* Can get more pictures later. https://imgur.com/uvSpKqq [https://imgur.com/sBcpK14 Last edited by Sneaky Chopsticks; 08-21-2019 at 08:56 PM.. |
| 240sx, nissan, s13, silvia |
