#34 |
Yup no problem, welded new brackets for the other z32 caliper in order to run the z32 rotor but before my friend welded it i had a template of where the other caliper was going then i had it chopped off.
#36 |
I bought a template and used it as a guide then had it marked on where the other tabs are going to be welded for the caliper. i used a hub and the z32 rotor to make sure everything was centered. After seeing that everything was were it should be i had someone cut the tabs of the template and welded the tabs.
#38 |
Just go with the pbm knuckle that fits the dual calipers. Ya they're out Barack but if you preorder pbm is good on shipping their product on time. Ply you save weight, has correction for slammed cars and more....
ピãƒÂ*アームMultilink Suspension - POWERED BY MAX |
