Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
#32 |
SPL KTS's are nice, SPLs are known to be a solid company that makes quality parts
check out my 240sx in my cardomain page 1 ![]() CLICK HERE TO SEE MY CARDOMAIN! help me decide my next set of rims ![]() |
#33 |
You could probably roll your own,
8 12.9 grade socket head bolts -$2 4 rod end ball joints,female threaded $9-20 4 rod end ball joint, male threaded $9-20 4 nuts to hold the ball joint in place -$1 8 spacers, could be nuts or similar -$1 8 nuts to hold the sway bar to the endlink. -$1 The only thing you'd need to find out is the loads the endlinks endure. It could be as cheap as $82 or as expensive as $170. (This is for the whole car btw) There are other ways to make them too, for packaging reasons you could change the above to use a ball joint linkage instead or whatever.
Finally down to 1 car again. Thank god. |
#34 |
Halo, where did you purchase your D2's from?? Im good friends with Mike from D2 USA/Urban Import. He dates a friend of mine, and has stayed at my apartment a few times, so its pretty easy to get a hold of him, haha! if you have any problems getting the warranty, maybe i can help you around it. no guarantee's, but ill see what i can do...
![]() HighTach Motorsports |
#35 |
from Canada, eh!
![]() Join Date: Sep 2001
I dealt with Mark from Advautoparts iirc. Now, what are the conditions for the recall? Noisy shocks? that's all?
-> HaLo Race Car: '98 E36 BMW M3 Daily Driver: '08 Fiji Blue Honda Civic Si SOLD: 01 GPW Honda S2000 PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET SOLD: 93 Super White 240SX SE Convertible w/Silvia Front |
#36 |
i think its a recall for all shocks made before a certain production, which isnt till like late this year, so it basically covers any D2's sold in NA. supposedly they are blowing out seals when used under a certain temperature.
#37 |
from Canada, eh!
I see... I have to send the coilovers back at my cost I believe right? What is the turnaround?
#39 |
from Canada, eh!
All right... time to contact Mark then.
#40 |
![]() Join Date: Feb 2003
Speaking of swaybars.... *puts on hijacker's ski mask*
I saw that Progress is coming out with a new set of sway bars for the S13 in the newest issue of Sport Compact Car. From the picture, they are 3-way adjustable and have solid endlinks with spherical metal bushings. Looks like a nice piece. Anyone have any info on these? I just emailed Progress, hopefully they are done with development so they can give me some specs. -Matt
'89 Nissan 240SX fastback: #23 DSP/RallyMod2/Track Slut '95 BMW 540i 6 speed: Ultimate Commuting Machine PFM Racing www.solo2.org www.midwest240sx.com |
#43 |
![]() Join Date: Apr 2003
Removing the front sway bar on a RWD car is not the thing to do. You are giving up overall grip in an attempt to make the car feel more balanced.
Jason '95 240sx SE |
#44 | |
![]() Join Date: Sep 2003
Hi |
#45 | |
He's probably gaining more mechanical grip this way than any other way. I would have run this way on a stock suspension at the track if my rear tires didn't lift up and spin (torsen diff) Since he has SPRINGAZZZ and stuff, that way will work fine for now. Probably needs a higher rate spring to get close to needing no bars front or rear. Or he could get a stiffer rear bar and run the stock bar up front. Upping the rear spring rates alot to run no bar back there could spell trouble for putting power down in corners though, I don't have any power so I don't know about that issue.
#47 |
Are you saying you do this on a Stock suspension car?
If so, this is definitely the wrong way to go. It is possible to use springs to not need swaybars, but with a stock suspension, you are just going to lose overall grip. I did about a half year on the stock front swaybar and otherwise stock suspension. That setup resulted in me killing the outside edge of my front tires. I added a bigger front swaybar which kept the car more level and resulted in keeping the tire flatter while cornering. Without a front swaybar, you are almost guaranteed to be giving up grip due to the amount of positive camber gained on the outside front tire. If you doubt this, get pictures of the car loaded in a corner, with and without the front bar. You are also giving up response time in transitions such as slaloms.
#48 |
I'm not using stock suspension and i have -2.5º Camber. Rates are 6.7k/5.5k with pillow ball mounts and the front doesnt really sway all that much more..it just rotates faster and steering response is crazy. The front end doesnt get unsettled over bumps anymore and steering feels a lot "lighter".
A perfect car wouldnt use sway bars...they are just a convenience for the manufacturer
Hi |
#50 |
A perfect car on a perfect track might not use swaybars. Unfortunately, no matter what springrate you pick, we are not dealing with either one of those. Check out some of the production-car based car races and pay attention to the swaybars they use. They're huge and some of them are also adjustable from the cockpit!
![]() I think the springrates that you are using are pretty low to be running without a front bar, I'd still like to see a picture of the front of your car, while loaded in a corner. I've got a Test & Tune coming up at the end of this month. You've got me interested enough to disconnect each swaybar on seperate runs. We should be setting up a skid pad area, so it would be interesting to collect data on each setup. Just need to find someone with a g-force meter that I can borrow.
#51 |
SOME NASA SE-R cup racers swear by the no front bar combo. BUT to work they run 600lb spring in a 2300lb car. With 500lb springs they use a front bar. Transistions are going to be much slower with out a bar so for autocrossing this makes little sence. But for roadcourse stuff you don't have as quick of transitions sometimes so you can give this up to gain some traction on the inside wheel in the front.
#52 |
Ok guys i just got back from the mountains this morning..i was out for 3 hrs testing the new setup. No front sway feels so friggin awesome. There were 4 roads we drove. One consisted of haripins for about 6 miles straight. Really harsh terrain and not friendly for stiff suspension. another road was smooth road with the fastest turn being about 70mph but usually about 40-60. another was high speed sweepers and the other was 50mph range again.
The hairpin road was so much better than last week. My front end definitely doesnt get jarred as much. It's the kind of road where you have to anticipate the turn-in because there are bumps and dips right before the turn. So you hit a bump then anticipate when your front end will re-gain traction and quickly turn in to make it through. My front end caught less air this time around and i went a lot faster overall. The high speed section 80+ is where you really feel the floaty feeling, but it still seems to grip more. The 50mph range is smooth as butter and it feels like i can go faster and faster. Trailbraking is soooo sex with this setup. the car rotates when you need it to and the steering wheel fights you less. i likey.. but i dont think i would use this for road race/drift. Only twisties and auto-x
Hi |
#53 |
![]() Join Date: Jan 2003
i wanna go to some mountains and test out my car!! im jealous. can anyone tell me some good ones in socal. pretty please!!
1990 s13 IslandMotorsports, Inc. |
#55 | |
Just for my setup. I think i'd need stiffer springs in the front to go faster without getting too much roll
Hi |
#56 |
It stands to reason that if the car feels good at 50mph, its going to be good at 90mph too. Maybe you should come out and test it on the 21st? 2 spots left lolololol
