Old 01-02-2009, 11:26 PM   #1
drifterdave
drifterdave's Avatar
drifterdave is on the path to ruindrifterdave is on the path to ruin
Exclamation msd balster 3 coil installed, now have problems!
ok so i bought a msd blaster 3 coil and i installed it. after the install my car wont start! i am blowing my 30amp ingition switch fuse, i replaced the fuese and had power to my interior. then once i tried to start it using my key, the starter was making like a click noise. so we tried jumping it and nothing. (i think by this point i had blown the fuese again). so we try push starting it, and still nothing. so i am wondoring if i installed the coil correctly.
heres what i did. i took my old coil off and cut the wires at the bottom, (pos + neg) then i put connectors on the stripped wires then attached them to the coil, + wire on to the pos + spot on the coil and the - wire on the neg spot on the coil. now the connector that i am guessing is a ground i placed on the neg side of the coil and tighted everything down. the thing that looks like the ingintor i left attached to the stock bracket.
sorry i dont have pics now but ill try and get some tommow.
please let me know if i installed the coil right. and what you guys think it could be.
thanks,
dave
keeping it gangster
drifterdave is offline   Reply With Quote
Old 01-03-2009, 09:08 PM   #2
drifterdave
please close thread, car is now fixed fucked up on my ground cable
keeping it gangster
