5.1/4" speakers in the front?
has anyone managed or know how to fit 5.1/4" speakers in the front of a s13 240SX?
im purchasing one soon, and I want to transfer my system from my civic over to the 240... i run Alpine Type R 5.1/4" component system in the front of the civic, but I just found out that the 240 runs mini 6x9's (forget what size they really are)... has anyone been able to create custom brackets to fit 5.1/4" or 6.5"?? |
1.) Search is king
2.) Mini 6x9's???? 6x9 is 6x9.... if there were such a thing as a mini 6x9 then wouldnt the dimensions be smaller henceforth cancelling the part "6x9" from its name. Thats like me saying there's a smaller 4" speaker that some people like to call a tweeter... My 90 Coupe has 4x6 in front and 6.8" in rear... |
![]() Join Date: Aug 2002
mini 6x9s. pwhaahahha ROFLLMFAO..
anyways, just cut out some custom baffles out of wood for the fronts and you can easily fit 5 1/4 or even 6 1/2 inch speakers in there. you can also make them out of plexi glass, but cutting plexi glass is a bitch.q |
Zilvia Contributor
![]() Join Date: Oct 2001
![]() ![]() Feedback Score: 1 reviews
You'll have to make a pattern of the old speaker frame and then create a new "frame" to hold the speakers. I used 2 clear plastic "drink trays" I found in the housewares department at Wal-Mart. They are about 1.5 feet in diameter and 1/8 of an inch thick. Get the clear ones so you can trace the speaker frame pattern onto them and cut them out with tin snips (or a hacksaw).
Heres the pattern I came up with. -m Last edited by mbmbmb23; 01-17-2007 at 12:09 AM.. |
WOW addicted
![]() Join Date: Dec 2001
If you use 1/4" MDF you can even use the stock screws.
I am running MB Quart Reference series Componants with the crossover velcro'd inside the door, and the tweeters mounted in the upper corner of the door skin (near dash)
