![]() Join Date: Apr 2005
I have to hit it for it to come up
What do I need to fix or replace to get it to work normal? |
![]() Join Date: Feb 2004
Have you tried greasing the latch it could be just stuck since its a old car? Also you may have to adjust the position of the hood latch by loosening up the bolts and shifting it up,down, left or right. You can also play with the hood alignment as well by loosening up the 4 12mm bolts at the hood hinges.
#3 | |
Instagram username:angelmkiv |
