![]() Join Date: Feb 2008
5 Speed Swap
Well I am going to do the 5 speed swap and would like to do it right. My question is; should I do the ECU and lower harness as well? I believe I need the ECU for some of the sensors but will the lower harness help me out at all. And can I just do the ECU and hook up all the sensors the right way without using the lower harness?
![]() Join Date: Dec 2002
The lower harness is useless. You'll have to run wiring anyway for neutral and 5th gear switches, having the harness doesn't help.
The ECU is fine, no need to swap it either.
No Limit Soldier.
![]() Join Date: Jan 2006
^Correct.
/Thread.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only" |
