Damned corner light won't come on!
I've got a silvia front end on a 93 coupe. My driver side corner light will not work. The bulb is good because it lights up on the other side.
The guy who had the car before me replaced the corner light and said that the harness or plug or something did not match up so he had to cut it and rewire it. The wires are red (power I would assume) and black (ground). The wires for the plug and the chassis have been wired but it still does not come on. I almost think that the plug part of the chassis harness is bad or something. The part where the actual plug and bulb plug in. Or maybe the wiring is messed up. If this is not enough information. I'll take some pics tomorrow and post them.
cardomain.com/ride/3113705 |
thats easy fix... if you really can't get it working, then ghetto fabricate it, tap into the the passenger side corner lights with your own wires , run them under the radiator support to hide the wires cleanly, and hook them up to your driver side corner lights.
Where theres a will theres a way... |
