My s13 speedometer has never worked properly. Sometimes it would work, but then it would just stop all of a sudden. And lately it hasn't been working. Usually I would have to smack the dash to make it start again but that doesn't seem to work anymore
Everything on the dash works besides the speedometer. What's up with my speedo? |
![]() Join Date: Feb 2012
Trader Rating: (37)
Correct.
The only thing that I could recommend would be to acquire another analog speedometer and see if it functions properly. It's a possibility that yours is near its deathbed. If the problem still persist, than there could be a wiring problem. Highly doubtful though. It's probably just the speedometer is shot. |
Trader Rating: (37)
If it is being shipped, I would by the entire cluster. Some people don't consider how fragile things are. If you can get it locally, buy just the meter. On most days, the entire clusters don't go for more than $50.
It's easy to change the meter. Split the black half from the white half. Grab a Philips screw driver. On the back of the cluster, behind the speedometer, there are 4 screws holding it in place. The screws are in a 4 square box pattern. Shouldn't be too difficult to determine the location. When you unscrew the last screw, the meter well fall right out, so be ready to catch it. |
#9 | |
