Wondering if anybody has ideas or a solution.
Car: 1996 240sx with s13 sr20det. Symptoms: Key in "on" position: normal power, power to ecu, etc. If I try to start the car it clicks once or twice then a buzzing comes from fuse area in the driver's side kick panel, then power cuts off. I have to disconnect the battery and wait for a couple of minutes, reconnect , then power comes back on. I have a brand new battery in (battery is relocated in the trunk) terminal connections are good; don't see any issues with fuses. I'm stumped. I just want to start her up and go for a drive!!!! Appreciate any help. |
Have you bench tested the starter?
My SR20VET |
| 240sx, engine bay harness, sr20det 240sx s13 |
