Old 02-15-2019, 01:20 PM   #1
ThomWilliams
ThomWilliams is an unknown quantity at this point
GReddy of Freddy?
hi all,
Looking for some GReddy experts. I’ve looked through previous threads and can’t make my mind up on if this manifold is a fake or not. Taken lots of photos so hopefully it’s easy to tell.
I’ve been sold this as a genuine GReddy intake
The previous owner had it recently soda blasted which makes it harder to tell.
Any help would be much appreciated!
ThomWilliams is offline   Reply With Quote
Old 02-16-2019, 06:45 AM   #2
Dboyizmlg
Dboyizmlg's Avatar
Dboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-knownDboyizmlg is making his/her stupidity well-known
Looks legit to me
Dboyizmlg is offline   Reply With Quote
Old 02-16-2019, 08:56 AM   #3
97nismo
97nismo's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
Even soda blasted the casting looks rough
If it’s a real greddy I wouldn’t run it
Feedback:
#/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 02-19-2019, 02:18 PM   #4
TheRealSy90
TheRealSy90's Avatar
It's a cast manifold, of course it looks "rough".
I can tell it's a real Greddy based off of the fittings at the rear end of the plenum. They used basically some sort of proprietary or discontinued fittings as i've tried to find exact matches before and couldn't. I'd bet on that one being real.
Also, clean it up and sell it if you aren't making 500hp cause the stock manifold will make more torque lol.
Such a good signature.
Old 02-25-2019, 09:00 AM   #5
jedi03
i say run it! makes the top end so much nicer! plus makes working on the engine/oil changes a dream compared to the stock manifold!
Old 02-26-2019, 08:03 AM   #6
tuzzio
tuzzio's Avatar
If you understood the cost / resources it takes to make a sand casting have a beautiful surface finish, you'd understand why it isn't more common. Unless you get into investment casting, which again, costs more money.
I'd like to see what tools you find available to get in there to clean any parting lines you feel aren't necessary where the cope/drag come together.
Also, some flow bench results on how you improved the overall process/product.
Car people have higher expectations for sand castings than aerospace components require.
Old 02-26-2019, 10:36 AM   #7
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
i dont think extrude honing is that expensive. it can get into every nook and cranny (no porting tools required).
jumpman2334 is offline   Reply With Quote
