![]() Join Date: Jan 2007
![]() ![]() Feedback Score: 9 reviews
GKTech - Eccentric Lockout Kits
S13/180sx/R32/R33/R34 Eccentric Lockout Kit (HICAS Equipped Cars)
The GKTECH eccentric lockout kit replaces the adjustable camber bolts that are prone to slipping under hard driving conditions and ensures that your wheel alignment stays where it was set. To suit HICAS equipped vehicles (also available for non HICAS equipped vehicles). Vehicle Compatibility: - Nissan S13 Silvia - Nissan 180sx - Nissan Skyline R32 GTS-T - Nissan Skyline R32 GT - Nissan Skyline R33 - Nissan Skyline R34 - Nissan C34 - Nissan C35 - Nissan A31 Cefiro Price: 25 AUD (approx. 21 USD) Shipping cost: From 22 AUD (approx. 21 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s13-...pped-cars.html S13/180SX/R32 Eccentric Lockout Kit (Non HICAS Equipped Cars) The GKTECH eccentric lockout kit replaces the adjustable camber and toe bolts that are prone to slipping under hard driving conditions and ensures that your wheel alignment stays where it was set. To suit non HICAS equipped vehicles (also available for HICAS equipped vehicles). Vehicle Compatibility: - Nissan S13 Silvia - Nissan 180sx - Nissan Skyline R32 GTS-T - Nissan A31 Cefiro NOTE: if you require S14, S15 or R33 etc. eccentric lockout kits please refer to our other listing to suit. Price: 36 AUD (approx. 31 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s13-...pped-cars.html S14/S15/R33 Eccentric Lockout Kit (Non HICAS) The GKTECH eccentric lockout kit replaces the adjustable camber and toe bolts that are prone to slipping under hard driving conditions and ensures that your wheel alignment stays where it was set. To suit non HICAS equipped vehicles (also available for HICAS equipped vehicles). Vehicle Compatibility: - Nissan S14 200SX - Nissan S15 200SX - Nissan Skyline R33 - Nissan Skyline R34 - Nissan C34 - Nissan C35 NOTE: if you require S13 Silvia, 180sx, R32 Skyline or A31 Cefiro etc. eccentric lockout kits please refer to our other listing to suit. Price: 36 AUD (approx. 31 USD) Shipping cost: From 36 AUD (approx. 34 USD) Zilvia.net intro offer of $30 shipping credit when you spend over $100 using the discount code "Zilvia.net" in the checkout for the month of July. ORDER HERE: http://www.gktech.com/index.php/s14-...non-hicas.html FAQ What is the advantage of installing the GKTECH eccentric lockout kit? The standard adjustable bolts are prone to slipping under hard driving conditions. The lockout kit ensures that there is zero movement. What about my camber/toe adjustment? The eccentric lockout kit is to be installed with adjustable arms. The arms alone should have more than enough adjustment that you'll ever need. What is the difference between the HICAS and non HICAS version of your kits? The HICAS kits only come with lockouts for camber where as if you don't have HICAS you will need twice as many bolts and washers to suit camber and toe lockout. What if I'm running an S14/S15 rear subframe in my S13/180sx? You will need to purchase an S14/S15 rear lockout kit. The bolt lengths are different between the 2 kits. For any inquiries please e-mail us at [email protected]. |
