Old 04-22-2016, 08:59 AM   #1
drfftn
drfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond repute
Determine if my car was auto or manual?
Anyone have a suggestions how to go about this? I've been trying to use vin decoders and it doesn't seem to work. Anyone know if I can look around the bay for anything visual that may tip me off?
Car is a 89 240
Edit: Did more research on the computer and not on my phone and found the correct results.
It's not in the VIN, but it is in the ID plate. It's the silver plate on the firewall under the hood. Third line down "Model," the code is broken up like this:
sample:
12345--67 (location)
RMLKS13FU (data)
1: R = Fastback, nothing = Coupe
2: M = KA24DE engine. SOHCs have a different letter
3: L = Left hand drive, R = RHD
4: K = HICAS, nothing = non-HICAS
5: S13 = Chassis
6: F = Manual, A = Automatic
7: U = 49 State, V = California, N = Canada
drfftn is offline   Reply With Quote
Old 04-22-2016, 10:02 AM   #2
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Well being that most swaps aren't that cleanly done check your firewall where the holes for the clutch pedal and master cylinder are made. If they look rough you have a swapped car.
[email protected]
hanzbrady is offline   Reply With Quote
Old 04-22-2016, 12:01 PM   #3
STR8 H8N
lololol
just look
pics?
we can tell you
Old 04-22-2016, 12:56 PM   #4
zombiewolf513
I assume its a manual now, are there a bunch of spare plugs down under the trans? Is the brake pedal an auto pedal cut in half? By the battery on the inner fender area is there a blue clutch interlock relay (if not it was an auto)? Looks like this...
If it was an auto, youll have a little "O/D OFF" orange light thing on the right side of the dash under the gauges... Its shown here right next to the windshield wiper handle and left of the rear defroster button...
Old 04-22-2016, 02:13 PM   #5
zerodameaon
zerodameaon's Avatar
That's not a great indication. I always ditch that OD light on any car I swap.
Need to adjust your idle?
#/f/s-chassis/395413...-pictures.html
Old 04-22-2016, 02:14 PM   #6
rawgarage
Banned from the Marketplace
Trader Rating: (75)
Feedback Score: 75 reviews
easy way is to check that clutch master hole.....
Old 04-22-2016, 02:25 PM   #7
zerodameaon
I agree, rarely do you see a clean hole and even when you do no one ever bothers to repaint them.
Mine is not a perfect hole but its also not a few holes drilled and beaten out with a hammer like you see quite often.
Old 04-22-2016, 04:42 PM   #8
zombiewolf513
Eh, just one possible indication. I gave a few others that dont involve trying to remove the master cylinder.
Old 04-22-2016, 09:52 PM   #9
rawgarage
Trader Rating: (75)
We said look.... You don't have to remove it... From in the bay it can be seen or peeping under the dash
Old 04-23-2016, 06:18 AM   #10
zombiewolf513
Why is this an on going argument? None of these possible indication areas anyone has listed are sure fire.
Old 04-23-2016, 11:40 AM   #11
rawgarage
Trader Rating: (75)
mannnnnnnn
Old 04-24-2016, 09:19 PM   #12
drfftn
Previous owner swapped over a 5 speed brake pedal. Also where the fuse box is they had the jumper harness that is required when converting the auto to 5 speed. The OD button was there too...
Old 04-24-2016, 10:46 PM   #13
rawgarage
Trader Rating: (75)
Could've looked at the clutch master bet your hole jagged AF
Old 04-24-2016, 10:56 PM   #14
zombiewolf513
Lay off the sauce man youre fallin off
Old 04-26-2016, 07:15 PM   #15
240.brendan
240.brendan is an unknown quantity at this point
On Hicas models f you're referring to what I think you are that's an indicator for whether or not that's working right.
Sent from my HTC One M9 using Tapatalk
240.brendan is offline   Reply With Quote
