![]() Join Date: Oct 2008
Trader Rating: (131)
SR20DET Engine & Transmission
Well guys, most of the items from my car have been sold and shipped to their new owners. I believe I have a buyer for the rolling chassis, so that leaves me with my engine and transmission. From what the previous owner told me, the engine is a 1994 S13 Blacktop. He swapped it into the car in 2001 and drove it for about 5k miles before he sold the car to me in 2008. I put about 32k miles on the engine while I owned it.
Here is a list of items I replaced on the engine and transmission about 25k miles ago: OEM Nissan oil pump OEM Nissan water pump OEM Nissan S14 oil pickup OEM Nissan timing chain & guides OEM Nissan timing chain tensioner OEM Nissan coolant temp sensor OEM Nissan coil packs OEM Nissan Pitwork Belts NISMO thermostat NISMO clutch pivot ball NISMO oil filter (used exclusively during ownership) Apexi head gasket ARP head studs GReddy oil pan Tomei Poncams (optional) DIF coolant temp sensor adapter (for water temp gauge sensor) Wiring Specialties S13 SR20DET into S13 chassis engine harness Wrinkle red valve cover Here is a list of items you will need/ that are NOT included with the drivetrain: Fuel rail Fuel injectors Turbo manifold Turbo Turbo elbow Coil pack cover Clutch Flywheel Coolant Piping (mine was modified to bypass the heater core) Shifter assembly Engine + transmission mounts ECU Current Pics: ![]() ![]() ![]() Included items that are not pictured are stock cams, stock intake manifold, starter, throttle body, stock FPR, etc. I inspected the bottom end of the engine when I rebuilt it and it was in great condition, so I did not replace the pistons, rings, bearings, etc. This engine was tuned professionally and never saw more than 15 psi of boost on a S15 turbo. It has always fired right up for me and has never given me any problems to speak of. Considering what I have invested, I am hoping to get $1700 OBO for my drivetrain setup with stock cams, or $1950 with Tomei Poncams. You may be able to get a more complete SR swap for $1800 or so, but it will of course be in questionable condition from Japan. This engine will save you a lot of work in that respect- throw a clutch/flywheel, fuel rail/injectors, and turbo/manifold of your choice at it and enjoy! I will not ship the engine and transmission or part with any items from either at this time. Local pickup in Howell, MI. PM me with questions or concerns. Thanks! Damon |
