![]() Join Date: Feb 2013
What’s up guys, I am in the middle of installing my isr pro arms and I’m having an issue with the rear upper arms. The bolt that goes through the side connecting to the knuckle is to large for the hole in the arm. So before I take out my drill I wanted to see if anyone else has had the same issue. The bolt is oem. Thanks for any help
![]() Join Date: Jul 2016
That's weird. Maybe the bolt had been replaced in the past and the previous owner just used whatever fit. If it is an actual oem bolt then I would just get a new 10.9 bolt and call it a day.
