Hey guys I recently found out about the plx gauge dm-100, which is basically a multi-functional gauge that connects to your obdII port and reads everything your ecu reads. I have a s13 hb with a rb25 series2 in it and I wanted to know if anyone has ran this gauge before with the same setup because Im trying to figure out how you would wire up the gauge because on a normal obd2 vehicle you would plug it in to your obd port and thats basically it. Thanks for any info in advance.
