Old 04-06-2008, 08:21 PM   #1
Devens240
Devens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really nice
Q45 brake upgrade
I picked up some rotors and calipers from a 91 infiniti Q45. will these will these fit on my S13? they are for the front btw
Devens240 is offline   Reply With Quote
Old 04-06-2008, 08:22 PM   #2
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
yes..
redrill rotor to 4 lug.
sillyvia13 is offline   Reply With Quote
Old 04-06-2008, 08:24 PM   #3
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
i believe that year will fit. i did the q45 swap and brakes are awesome. make sure to resurface the rotors before you use them and make sure they are within specs, i think 26mm min or something like that. if you need a bmc upgrade let me know i've got a couple laying around. also...do a search next time, there's plenty of info out there about the q45 brake up grade. direct bolt on. good luck
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 04-06-2008, 08:25 PM   #4
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
ALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfectionALEXTHESUS*PECT is close to perfection
Send a message via AIM to ALEXTHESUS*PECT
look here:
#/f/showthread.p...ight=q45+brake
TEAM SUS*PECT
ALEXTHESUS*PECT is offline   Reply With Quote
Old 04-06-2008, 08:27 PM   #5
Devens240
yeah i know i have to re-drill them. but i have read that 90-96 Q45 calipers will work but on one website it said only 94-96 will work?
Old 04-06-2008, 08:28 PM   #6
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
theyll fit
you have to cut the weather guard craps to get the rotors to work but they are bolt on
search nextime
joshchewuhh is offline   Reply With Quote
Old 04-06-2008, 08:30 PM   #7
ALEXTHESUS*PECT
one more for you:
Originally Posted by mellojoe View Post
I did the q45 brake upgrade. You do NOT need anything special. Just go to AutoZone and buy a loaded pair of calipers and a pair of rotors for a 1995 Infiniti Q45. You can use stock brake lines, and the stock mounts. However, I would suggest picking up a set of braided stainless steel brake lines. Just buy OEM replacement for your 240sx.
I went to tirerack.com and picked up Brembo rotors for the Q45, brake lines for an s14. Then I went to O'Reiley's and picked up a set of loaded calipers for a 1995 Q45. You have to pay a core charge.
But, I returned my s14 front calipers for the core charge. I even told the guy what I was doing, and he was fine with it. However, most people don't know the difference between the s14 and Q45 calipers, so they won't pay attention if you return your s14 calipers as q45 calipers and don't say anything. I'm not suggesting you do this, but I'm sure it would work.
This was for the fronts only. Front calipers + front rotors + brake lines for all corners.
TEAM SUS*PECT
Old 04-06-2008, 08:33 PM   #8
Devens240
"IRC it's 92-96...maybe '90-96"
thats what was said thats why im worried lol i got mine off a 91. and i had them turned and i could use a BMC upgrade how much are you asking sogu?
Old 04-06-2008, 08:33 PM   #9
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
The only thing that I don't like about the Q brakes is the lack of race pads for them. If it wasn't for that I would be doing this conversion.
racepar1 is offline   Reply With Quote
Old 04-06-2008, 08:34 PM   #10
ALEXTHESUS*PECT
you shouldn't have anymore questions when you read this link.
also go 5 lug and get s14 95-95 se rotors for the rear at the same time!
http://www.ka24development.com/brake_upgrades.html
TEAM SUS*PECT
Old 04-06-2008, 08:37 PM   #11
Devens240
ok i have reaserched and read tons of Q45 brake swap stuff, what im asking is will 91 calipers fit? some DIY say they will and some say they wont so does anyone have 91 Q45 calipers? sorry to be an ass haha
Old 04-06-2008, 08:37 PM   #12
joshchewuhh
Trader Rating: (56)
yaaaaa ditto
theres hawk pads
Old 04-06-2008, 08:40 PM   #13
ALEXTHESUS*PECT
The ’90-’96 Infiniti Q45 is a V-8 powered 4100 pound beast requiring LARGE brake to stop it safely.
Luckily for 240sx owners, these big brakes bolt right on - all you have to do is remove the heat shield.
Q45 brake calipers have 2-pistons (43mm each compared to a single 54mm piston on the stock calipers), the rotors are 11 inches in diameter and 28mm thick, the larger pads have about 40% more surface area, and the two pistons will give you about 25% more clamping force compared to the stock brakes...
TEAM SUS*PECT
Old 04-06-2008, 08:44 PM   #14
Devens240
yeah i have read that its from nicoclub if im not mistaken. but some other DIY's say you can only use 94-96. guess ill have to try them out lol
Old 04-06-2008, 08:51 PM   #15
racepar1
racepar1's Avatar
Originally Posted by joshchewuhh View Post
yaaaaa ditto
theres hawk pads
Only hp+ though, no blues or blacks!
Old 04-06-2008, 08:56 PM   #16
ALEXTHESUS*PECT
noooooot nico. i gave the link already!
TEAM SUS*PECT
Old 04-06-2008, 09:01 PM   #17
articdragon192
articdragon192's Avatar
I used Endless pads in mine. Endless makes pads for the Q45s.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 04-06-2008, 09:18 PM   #18
racepar1
racepar1's Avatar
Endless is waaaaaayyyyyyyyyyy overpriced though! And I must correct my previous post it is the hps's not the hp+'s.
Old 04-06-2008, 11:02 PM   #19
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
theyll fit
search nextime
When you do this, don't forget to CHECK YOUR CLEARANCE. I did this, and couldn't figure out why I got a LOUD screeching/scraping noise, even after double checking. Turns out that I didn't peel back (after cutting) enough of it on the inside of the rotor (closest to the engine). It dug an indention into my brand new slotted Q45 rotor -_- Small, not enough to affect performance.
Neejay is offline   Reply With Quote
Old 04-06-2008, 11:07 PM   #20
racepar1
racepar1's Avatar
theyll fit
search nextime
Just remove the dust shields completely. They're not spot welded or anything, just pressed on. All you need ia a flathead screwdriver and a hammer. If you're careful you can remove them without even damaging them.
Old 04-06-2008, 11:09 PM   #21
Devens240
ok thanx for all the help! now i just need to upgrade my BMC
Old 04-07-2008, 12:37 AM   #22
Aoshi112
Aoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really niceAoshi112 is just really nice
Send a message via AIM to Aoshi112
you could get carbotech to make you a set of q45 race pads. A bit pricy but from what i've been told, Carbotech brakes are pretty awesome.
Aoshi112 is offline   Reply With Quote
Old 04-07-2008, 05:35 AM   #23
smelly240
smelly240's Avatar
smelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfectionsmelly240 is close to perfection
POOOORRRTEEEERRFIIIEEELLLDDD
they make pads :P
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 04-07-2008, 06:12 AM   #24
yarou
yarou's Avatar
yarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfectionyarou is close to perfection
Just adjust your stock BMC so the pedal doesn't hit the floor.
jumbosandbox.blogspot.com
yarou is offline   Reply With Quote
Old 04-07-2008, 10:40 PM   #25
articdragon192
I ran the SS-S and they run 160 retail I believe. Amazing pads. I run those on my Z32 with the stock 26mm aluminum calipers and I have yet to fade the brakes. I've boiled my fluid before even getting to fading the brakes.
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 04-07-2008, 10:52 PM   #26
ALEXTHESUS*PECT
for the q45 upgrade nothing needs to be done to the brake master cylinder. for the z32 yes, but not the q45 ones. get stainless steel lines, rotors, ichiba 5 lug hubs, and some wheels to get you started.
TEAM SUS*PECT
Old 04-07-2008, 10:54 PM   #27
Neejay
Neejay's Avatar
After mine, my brake pedal was squishy and went all the way to the floor (properly bled - speedbleeders all around). I had to adjust my brake pedal stiffness via the brake booster adjust rod.
Old 04-07-2008, 11:27 PM   #28
Devens240
ok thankyou, what are some BMC upgrade options? cuz that would do more for me than adjusting to booster correct? btw its a manual S13
