Old 04-12-2011, 05:09 PM   #1
Pro ViZIon
Pro ViZIon's Avatar
Pro ViZIon is an unknown quantity at this point
s13 Turn Signals Dont Work & All power wont turn off.
ok so i have a 90 s13 hatch with a ka24de swap.
My first issue is that my turn signals don't work. They dont even show up on the indicators when switched. My hazards work and all of the bulbs are good so im not sure what its wrong.
My second issue is that even with the key turn to off and key out i still have power to basically everything. the only thing that i know turns off is my stereo.
Everything in the engine bay still has power. ecu has power as well as the dummy lights in the cluster. the only way to actually get all of it to shut off is buy disconnecting the battery of course or pulling either the egi or egi pump relays. I have checked all fuses and they were all fine.
I'm not sure if the two problems relate in anyway but this whole thing started a little prior to me starting the swap. it was fine before hand but was sitting for some time. about 4 months.
Thanks for any help.
1990 Nissan 240SX w/KA24DE - New project
1984 Mazda RX-7 GSL-SE 13B
Pro ViZIon is offline   Reply With Quote
Old 04-12-2011, 06:59 PM   #2
Redred
Redred is an unknown quantity at this point
i wish i could help but im a newbie
Redred is offline   Reply With Quote
Old 04-12-2011, 07:01 PM   #3
Pro ViZIon
Pro ViZIon's Avatar
Haha no problem
Old 04-12-2011, 07:03 PM   #4
Sileighty_85
Sileighty_85's Avatar
for the Turn signals, might be the switch
the Power thing, almost sounds like either the Igniton switch is bad or a relay is sticking closed.
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-12-2011, 09:12 PM   #5
Pro ViZIon
Pro ViZIon's Avatar
I don't think the ign switch is bad since my stereo turns off as it should. I'm not sure what really I should be checking for though.
Old 04-12-2011, 09:14 PM   #6
Sileighty_85
try swapping the two green relays around in the engine bay fuse box on the passenger strut tower and see if that fixes it
後輪駆動車1番
1986 SR86 - 200ish
Old 04-12-2011, 10:49 PM   #7
nujabe
nujabe's Avatar
check your fuse box its probly blown . or check to see if you hazard button and defrost is plug in because they wont work if there not in
Old 04-12-2011, 11:29 PM   #8
Pro ViZIon
Pro ViZIon's Avatar
Ok just tried that and nothing. I don't think those are the issue. But then again I'm no good with electrical.
Old 04-12-2011, 11:36 PM   #9
Schassis707
Schassis707's Avatar
Trader Rating: (18)
Schassis707 is an unknown quantity at this point
Feedback Score: 18 reviews
flasher relay... i have an extra ill sell you ill shoot you a pm..
Originally Posted by eddieflo View Post
use paint colors from other vehicles on your 240 too bolts right on
Schassis707 is offline   Reply With Quote
Old 04-13-2011, 11:46 AM   #10
nujabe
nujabe's Avatar
go undear your steering wheel check the the fuse that control the turn signal lights . swap it out for another one. did you try that.
Old 04-13-2011, 12:47 PM   #11
Pro ViZIon
Pro ViZIon's Avatar
You talking about the fuse in the fuse panel. Yeah I checked that. 10 amp right. It was fine.
Old 04-13-2011, 01:32 PM   #12
nujabe
nujabe's Avatar
dam im stumped then i had the same problem turned out being a combo of both dead fuse and not being plug in.
Old 04-13-2011, 01:40 PM   #13
Pro ViZIon
Pro ViZIon's Avatar
Well ill check the defroster swwitch again. I know the hazard switch is hooked up cause they work.
Old 04-13-2011, 04:15 PM   #14
emu103
emu103 is an unknown quantity at this point
my sr20 ecu got fried, and repaired.
now it never shuts off, i have to stall my car out and unplug the ecu or it kills my battery.
maybe...
emu103 is offline   Reply With Quote
Old 04-13-2011, 05:10 PM   #15
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
just get another signal stalk, as for everything still being powered on after, you may need to check your wiring sounds like there is a constant 12v wire connected where a 12v ignition switched should be, just a thought, who did the wiring for the swap?
Mishkin_707 is offline   Reply With Quote
Old 04-13-2011, 06:45 PM   #16
Pro ViZIon
Pro ViZIon's Avatar
I did the wiring but it was like thise prior to the swap.
Old 04-14-2011, 06:34 PM   #17
Mishkin_707
oh ok, its going to be a pain in the ass to go through all the wiring but you're gonna have to, check to see where the constant 12v wiring should be and check where the ignition switched 12v should be also check under the steering column make sure nothing is crossed also, but for the easiest thing, just check all the relays under the hood make sure none of them are just sticking
Old 04-18-2011, 06:38 AM   #18
Xxs13240xX
Xxs13240xX's Avatar
Xxs13240xX is an unknown quantity at this point
Try looking under your drivers side fender and check out the wiring harness running up there you may have rubbed through it it's pretty common on the s chassis
Xxs13240xX is offline   Reply With Quote
Old 04-18-2011, 11:58 AM   #19
Pro ViZIon
Pro ViZIon's Avatar
You know I was thinking of checking that out. The car hasn't moved in so long though. But its worth checking.
Old 04-21-2011, 06:32 PM   #20
Pro ViZIon
Pro ViZIon's Avatar
Ok so my turn signals work out of no where lol. I'm definately fine with that.
But power still stays on. I noticed when I unplugged the ecu everything shuts off as it should. So could it be my wiring for the swap. I remember this being an issue prior to the new motor going in but idk. Its been so long now.
Old 04-21-2011, 07:01 PM   #21
Pro ViZIon
Pro ViZIon's Avatar
Nvm on the wiring. I looked it over and everything is wired where it should.
Any other ideas guys. Its weird that it works with the ecu unplugged.
Old 04-22-2011, 08:27 AM   #22
conrad_s13.5
conrad_s13.5's Avatar
check the brown plug,...i know you said you checked everything, but i guess just for the sake of this thread and trouble shooting.....lol
red/black is ecu back up power i believe, and red is constant (could be viseversa,. but yeah,.)
was the car ever wired up with a turbo timer?,...could have messed that up.
Could also get a test light or multi meter, and check the connections on the ignition. See if they're working the way they are supposed to, or if there is a short/frayed wiring touching any of those connections.
cONtRol FReAkS
Old 04-22-2011, 12:41 PM   #23
Pro ViZIon
Pro ViZIon's Avatar
I'm not exactly sure how to test for this lol. And what plug are you refering too? Where is it at?
And it had no turbo timer previously.
Old 04-22-2011, 07:25 PM   #24
cotbu
cotbu's Avatar
I think I can lead you in the right direction. Your problem with the 12v system sounds like and energized relay sticking or something is leaching power from a relay and it can't close or open after ignition is off. Sometimes people improperly install efans or electronics that cause that same effect. Are there any electric fans, or aftermarket electronics on the vehicle at all? I would start there or pull all fuses, 1 at a time until power turns off. I always schedule wiring jobs on cool days because it can take hours to even identify the cause,
Old 04-22-2011, 09:56 PM   #25
Pro ViZIon
Pro ViZIon's Avatar
I do have any e-fan but I know for sure its not the problem since its not hooked up through any of the engine bay electrical. The power does shut off if it pull out the egi or egi pump relays or the 25amp engin cont fuse. I don't think either of those relays is stickings since I swapped them around and there was no difference. I'm not sure how to test the relays. I looked in my chilton manual but it didn't have anything for that. Maybe the fsm has a procedure for testing these relays.
Old 04-23-2011, 02:31 PM   #26
cotbu
cotbu's Avatar
Just giving a direction to look, as for pinpointing the problem. Pull all fuses and relays except for egi/egipump and the main 75/100amp fuses . Ps idont mean the relay itself is sticking nevermind, I'm sure you'll figure it out.
Hey the good news is I just saved a crap load on car insurance.
Sent from my SGS VIBRANT using Tapatalk
Old 04-27-2011, 02:06 AM   #27
Pro ViZIon
Pro ViZIon's Avatar
Congrats on your new insurance rate lol.
But it will turn off with the "eng cont" 25amp fuse pulled out.
I also checked the body harness under the driver side fender well and it was fine.
Old 05-02-2011, 10:39 PM   #28
Pro ViZIon
Pro ViZIon's Avatar
Ok so i figured out why the power doesn't shut off. My ecu was bad apparently. I pulled it apart to look for signs of it being fried but apparently it was just bad some how. wasnt burnt or anything.
Old 05-04-2011, 10:02 AM   #29
nissan junky
nissan junky's Avatar
nissan junky is an unknown quantity at this point
Any bad solder joint or they call it a cold solder joint i think ..some time you need a mag glass to see these littel things if you can find it..just give her a littel solder and you will be good...With the exception of a new ECU..
nissan junky is offline   Reply With Quote
Old 05-04-2011, 10:08 AM   #30
bb4_96
bb4_96 is an unknown quantity at this point
So it works with another ECU?
bb4_96 is offline   Reply With Quote
electrical, power, relay, signal, turn
